Zum Hauptinhalt wechseln
Removing the Behringer Eurolive B212D Electronics Box
Was du brauchst
  1. Removing the Behringer Eurolive B212D Electronics Box, Removing the Behringer Eurolive B212D Electronics Box: Schritt 1, Bild 1 von 1
    • CAUTION: Unplug your speaker from the power outlet.
    • Remove the 8 Phillips screws from the back of the speaker.
  2. Removing the Behringer Eurolive B212D Electronics Box: Schritt 2, Bild 1 von 1
    • Carefully remove the back panel, lifting out the metal electronics-box with it.
    • To avoid damaging your speaker, remove slowly, as there is still a wire attached from the electronics box to the speaker.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Troy W. Weber
1.431 Reputation
6 Anleitungen geschrieben
2 Kommentare
I want to buy the hole back panel, but I don't where?, tell me
miguelangelvera63 - Antwort
I will wait for answer
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 13
Insgesamt: 3,528
