Zum Hauptinhalt wechseln
Disassembling Marshall MS-2 Micro Amp Case Disassembly
Was du brauchst
  1. Disassembling Marshall MS-2 Micro Amp Case Disassembly, Disassembling Marshall MS-2 Micro Amp Case Disassembly: Schritt 1, Bild 1 von 1
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
  2. Disassembling Marshall MS-2 Micro Amp Case Disassembly: Schritt 2, Bild 1 von 3 Disassembling Marshall MS-2 Micro Amp Case Disassembly: Schritt 2, Bild 2 von 3 Disassembling Marshall MS-2 Micro Amp Case Disassembly: Schritt 2, Bild 3 von 3
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Disassembling Marshall MS-2 Micro Amp Case Disassembly: Schritt 3, Bild 1 von 2 Disassembling Marshall MS-2 Micro Amp Case Disassembly: Schritt 3, Bild 2 von 2
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  4. Disassembling Marshall MS-2 Micro Amp Case Disassembly: Schritt 4, Bild 1 von 1
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
MacKinley
811 Reputation
5 Anleitungen geschrieben
University of Maryland, Team 1-1, Shastany Fall 2013 Mitglied von University of Maryland, Team 1-1, Shastany Fall 2013
UMD-SHASTANY-F13S1G1
3 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 22
Insgesamt: 2,060
