Einleitung
This guide will illustrate how to remove the heat sink from your PowerMac.
Was du brauchst
Pull on outer latch.
Lower door until it is level with your work surface.
Use the spudger to pry the clips horizontally off of the heat sink.
Fully remove the clips by lifting upwards.
Fast fertig!
Ziellinie
6 weitere Nutzer:innen haben diese Anleitung absolviert.
