Zum Hauptinhalt wechseln
Disassembling of Wahl Lithium Ion Trimmer
Was du brauchst
  1. Disassembling of Wahl Lithium Ion Trimmer, Disassembling of Wahl Lithium Ion Trimmer: Schritt 1, Bild 1 von 2 Disassembling of Wahl Lithium Ion Trimmer, Disassembling of Wahl Lithium Ion Trimmer: Schritt 1, Bild 2 von 2
    • Begin by removing the rubber grip along the handle.
  2. Disassembling of Wahl Lithium Ion Trimmer: Schritt 2, Bild 1 von 1
    • Remove the screws from the top to take the metal piece and plastic part off.
  3. Disassembling of Wahl Lithium Ion Trimmer: Schritt 3, Bild 1 von 2 Disassembling of Wahl Lithium Ion Trimmer: Schritt 3, Bild 2 von 2
    • Pry open the plastic cover into two separate pieces. The plastic is very durable so don't worry about breaking it upon prying it open.
Abschluss
12 weitere Nutzer:innen haben diese Anleitung absolviert.
nathan
1.410 Reputation
6 Anleitungen geschrieben
University of Maryland, Team 1-3, Shastany Fall 2013 Mitglied von University of Maryland, Team 1-3, Shastany Fall 2013
UMD-SHASTANY-F13S1G3
3 Mitglieder
3 Kommentare
Well this does not show how to properly remove the metal piece that surrounds the power button , which needs to be removed to access 2 screws ( that I can see it) that need to be removed to completely separate the plastic encasement of the intrrnals has
Andrew Beeson - Antwort
very helpful for the first two steps. I need like six more between the 2nd step and the last step. but otherwise, very helpful.  Thank you so much
tundraorchid - Antwort
Thanks…worked well.
Magpie - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 6
Letzte 7 Tage: 49
Letzte 30 Tage: 193
Insgesamt: 43,620
