Zum Hauptinhalt wechseln
Sony Radio Model CFD S05 Prerequisite steps Replacement
Grundständige Anleitung
Dies ist eine grundständige Anleitung, die nur als Teil einer anderen Anleitung verwendet werden sollte.
Was du brauchst
  1. Sony Radio Model CFD S05 Prerequisite steps Replacement, Sony Radio Model CFD S05 Prerequisite steps Replacement: Schritt 1, Bild 1 von 1
    • Unscrew the screws on the top of the radio.
  2. Sony Radio Model CFD S05 Prerequisite steps Replacement: Schritt 2, Bild 1 von 2 Sony Radio Model CFD S05 Prerequisite steps Replacement: Schritt 2, Bild 2 von 2
    • Open the CD and cassette doors and remove the screws in the compartments.
    • To open the CD door push on the bottom left corner of the CD door. To open the cassette door push the button that is to the left of the pause button.
  3. Sony Radio Model CFD S05 Prerequisite steps Replacement: Schritt 3, Bild 1 von 1
    • Flip the radio upside down and remove the battery cover. Unscrew the one screw below the batteries.
  4. Sony Radio Model CFD S05 Prerequisite steps Replacement: Schritt 4, Bild 1 von 1
    • Remove the top of the radio enough to access the wires for removal.
    • Do not forcefully remove the whole top piece of the radio! There will be wires connected to the top cover and circuit board.
  5. Sony Radio Model CFD S05 Prerequisite steps Replacement: Schritt 5, Bild 1 von 1
    • Remove all of the wires that are connected to both the circuit board and the underside of the top of the radio by pulling them where they are connected
    • This should include three sets of red and white wires, one set of white wires, one set of black wires, and two ribbon wires. Some cannot be disconnected from the top piece of the radio. Disconnect these plugs from the circuit board.
Ziellinie
Ian Nussman
959 Reputation
6 Anleitungen geschrieben
UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013 Mitglied von UMass Dartmouth, Team 2-5, Gulbrandsen Fall 2013
UMASSD-GULBRANDSEN-F13S2G5
2 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 11
Insgesamt: 99
