Zum Hauptinhalt wechseln
Disassembling Marshall MS-2 Partner Circuit Board
Was du brauchst
  1. Disassembling Marshall MS-2 Partner Circuit Board, Disassembling Marshall MS-2 Micro Amp Case Disassembly: Schritt 1, Bild 1 von 1
    • First be sure to turn the power switch to the off position.
    • Do this by turning the leftmost knob counter-clockwise as until the line points to "off."
  2. Disassembling Marshall MS-2 Partner Circuit Board: Schritt 2, Bild 1 von 3 Disassembling Marshall MS-2 Partner Circuit Board: Schritt 2, Bild 2 von 3 Disassembling Marshall MS-2 Partner Circuit Board: Schritt 2, Bild 3 von 3
    • Now remove the battery.
    • On the back of the device locate the battery cover.
    • Remove it by pushing down on the clip.
    • Then pull the piece of fabric until the battery comes out.
  3. Disassembling Marshall MS-2 Partner Circuit Board: Schritt 3, Bild 1 von 2 Disassembling Marshall MS-2 Partner Circuit Board: Schritt 3, Bild 2 von 2
    • Use the long, skinny phillips head screwdriver to remove the 4 7/16" screws on the back of the device in the four corners.
    • Once unscrewed, do not try to take each screw out. Move to next step once all screwed have been unscrewed.
  4. Disassembling Marshall MS-2 Partner Circuit Board: Schritt 4, Bild 1 von 1
    • Now pull the back panel off and place it down as shown. Pull the panel straight up so you do not lose the screws.
  5. Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: Schritt 5, Bild 1 von 2 Disassembling Marshall MS-2 Partner Circuit Board, Partner Circuit Board: Schritt 5, Bild 2 von 2
    • Use a 9/16" socket to remove the nut around the headphone jack. Be careful to not lose the washer.
  6. Disassembling Marshall MS-2 Partner Circuit Board: Schritt 6, Bild 1 von 1
    • Remove the 7/16" phillips head screw.
  7. Disassembling Marshall MS-2 Partner Circuit Board: Schritt 7, Bild 1 von 1
    • Grab the headphone jack from inside the case and pull it toward the speaker until you can fully remove it from the device.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
MacKinley
796 Reputation
5 Anleitungen geschrieben
University of Maryland, Team 1-1, Shastany Fall 2013 Mitglied von University of Maryland, Team 1-1, Shastany Fall 2013
UMD-SHASTANY-F13S1G1
3 Mitglieder
Ein Kommentar
There Is a toroidal transformer inside ?
Jack redmond - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 1
Letzte 30 Tage: 11
Insgesamt: 1,846
