Zum Hauptinhalt wechseln
Disassembling Sony Ericsson QuickShare T630 Phone Enclosure
Was du brauchst
  1. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure, Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 1, Bild 1 von 1
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 2, Bild 1 von 2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 2, Bild 2 von 2
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 3, Bild 1 von 1
    • Slide the battery upward to remove.
  4. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 4, Bild 1 von 2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 4, Bild 2 von 2
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
  5. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 5, Bild 1 von 2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 5, Bild 2 von 2
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  6. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 6, Bild 1 von 1
    • Slide the aerial upward to remove it.
  7. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 7, Bild 1 von 2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 7, Bild 2 von 2
    • Remove the four screws located at each corner of the device.
  8. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 8, Bild 1 von 2 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 8, Bild 2 von 2
    • Gently lift and remove the front panel of the phone after removing the screws.
  9. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 9, Bild 1 von 3 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 9, Bild 2 von 3 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 9, Bild 3 von 3
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit.
    • Remove the now disconnected screen.
  10. Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 10, Bild 1 von 3 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 10, Bild 2 von 3 Disassembling Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 10, Bild 3 von 3
    • Remove the keyboard by slowly pulling it away from the circuit board.
    • There are no direct connections between the keyboard and phone.
    • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
University of Maine, Team 1-13, Diaz Fall 2013 Mitglied von University of Maine, Team 1-13, Diaz Fall 2013
UMAINE-DIAZ-F13S1G13
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 10
Letzte 30 Tage: 19
Insgesamt: 3,526
