Zum Hauptinhalt wechseln
Sony Ericsson QuickShare T630 Screen Replacement
Was du brauchst
  1. Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Phone Enclosure: Schritt 1, Bild 1 von 1
    • Begin the disassembly by placing your Sony Ericsson QuickShare T630 on a flat surface.
  2. Sony Ericsson QuickShare T630 Screen Replacement: Schritt 2, Bild 1 von 2 Sony Ericsson QuickShare T630 Screen Replacement: Schritt 2, Bild 2 von 2
    • Slide the protective panel on the backside of the phone downward and remove it entirely, revealing the battery underneath.
  3. Sony Ericsson QuickShare T630 Screen Replacement: Schritt 3, Bild 1 von 1
    • Slide the battery upward to remove.
  4. Sony Ericsson QuickShare T630 Screen Replacement: Schritt 4, Bild 1 von 2 Sony Ericsson QuickShare T630 Screen Replacement: Schritt 4, Bild 2 von 2
    • Remove the rubber plug located near the camera by gently prying upward with your fingers.
    • Gently lift the camera shield after removal of the rubber plug.
  5. Sony Ericsson QuickShare T630 Screen Replacement: Schritt 5, Bild 1 von 2 Sony Ericsson QuickShare T630 Screen Replacement: Schritt 5, Bild 2 von 2
    • Pry the remaining panel to loosen its contact to the phone using a spudger.
    • Slide the panel upward to remove it completely.
    • These steps will require a slight appliance of force.
  6. Sony Ericsson QuickShare T630 Screen Replacement: Schritt 6, Bild 1 von 1
    • Slide the aerial upward to remove it.
  7. Sony Ericsson QuickShare T630 Screen Replacement: Schritt 7, Bild 1 von 2 Sony Ericsson QuickShare T630 Screen Replacement: Schritt 7, Bild 2 von 2
    • Remove the four screws located at each corner of the device.
  8. Sony Ericsson QuickShare T630 Screen Replacement: Schritt 8, Bild 1 von 2 Sony Ericsson QuickShare T630 Screen Replacement: Schritt 8, Bild 2 von 2
    • Gently lift and remove the front panel of the phone after removing the screws.
  9. Sony Ericsson QuickShare T630 Screen Replacement: Schritt 9, Bild 1 von 3 Sony Ericsson QuickShare T630 Screen Replacement: Schritt 9, Bild 2 von 3 Sony Ericsson QuickShare T630 Screen Replacement: Schritt 9, Bild 3 von 3
    • This step is NOT required for joystick maintenance or keypad maintenance and replacement! Continue on to step 10 if you are attempting to achieve either of these goals.
    • Slowly lift the screen to reveal the green circuit ribbon connecting the screen to the phone.
    • Gently pull the ribbon from the circuit.
    • Remove the now disconnected screen.
  10. Sony Ericsson QuickShare T630 Screen Replacement: Schritt 10, Bild 1 von 3 Sony Ericsson QuickShare T630 Screen Replacement: Schritt 10, Bild 2 von 3 Sony Ericsson QuickShare T630 Screen Replacement: Schritt 10, Bild 3 von 3
    • Remove the keyboard by slowly pulling it away from the circuit board.
    • There are no direct connections between the keyboard and phone.
    • These are all of the parts covered in this disassembly that make up the Sony Ericsson QuickShare T630.
  11. Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: Schritt 11, Bild 1 von 3 Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: Schritt 11, Bild 2 von 3 Sony Ericsson QuickShare T630 Screen Replacement, Sony Ericsson QuickShare T630 Screen: Schritt 11, Bild 3 von 3
    • To place a new screen, slide the green ribbon connector into the ribbon clamp that the defective screen was pulled from.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Jeremy
166 Reputation
1 Anleitung geschrieben
University of Maine, Team 1-1, Diaz Fall 2013 Mitglied von University of Maine, Team 1-1, Diaz Fall 2013
UMAINE-DIAZ-F13S1G1
4 Mitglieder
6 Anleitungen geschrieben
Ein Kommentar
Worked well until the screen replacemet - ribbon cable would not go into clamp - phone plus new screen straight in the bin - a little gutted - but hey it was an old but loved phone.
roger hiley - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 13
Insgesamt: 1,332
