Zum Hauptinhalt wechseln
2001-2005 Honda Civic Battery Replacement
Was du brauchst
  1. 2001-2005 Honda Civic Battery Replacement, Battery: Schritt 1, Bild 1 von 1
    • Caution! Vehicle must be turned off before attempting this replacement. Touching the battery terminals while the car is running may cause risk of electrocution.
  2. 2001-2005 Honda Civic Battery Replacement: Schritt 2, Bild 1 von 1
    • Remove the connections from both the negative and the positive terminals of the battery
    • When removing the battery, the negative terminal must be removed first. When re-installing the battery, the positive must be connected first.
  3. 2001-2005 Honda Civic Battery Replacement: Schritt 3, Bild 1 von 1
    • Using a socket wrench, remove the battery bracket from the top of the battery.
    • Depending on the condition of the car, the bolts may be rusted, making the removal of them a challenge.
  4. 2001-2005 Honda Civic Battery Replacement: Schritt 4, Bild 1 von 1
    • Ensure that there are no connections remaining on the battery.
    • Lift up the battery and remove it from the battery tray.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Tyler Smith
810 Reputation
3 Anleitungen geschrieben
UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013 Mitglied von UMass Dartmouth, Team 4-5, Vijaybhaskar Fall 2013
UMASSD-VIJAYBHASKAR-F13S4G5
3 Mitglieder
5 Anleitungen geschrieben
Ein Kommentar
Terrible! These sparse instructions leave out so many steps, both for safety and for completion of the task, that anyone performing this task for the first time will have no idea what to do.
Mark - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 10
Letzte 7 Tage: 53
Letzte 30 Tage: 215
Insgesamt: 35,720
