Zum Hauptinhalt wechseln
BlackBerry 7510 LCD Screen Replacement
Was du brauchst
  1. BlackBerry 7510 LCD Screen Replacement, Back Face of Phone: Schritt 1, Bild 1 von 1
    • Remove the battery cover and battery before continuing.
    • Remove the six T6 Torx screws on the back of the phone.
    • Make sure to keep the screws somewhere that they will not get lost.
  2. BlackBerry 7510 LCD Screen Replacement: Schritt 2, Bild 1 von 1
    • Using your finger nail or a spudger, carefully pry up the back cover.
    • Begin in one spot and slowly circle around the device as you pry up all of the back cover.
  3. BlackBerry 7510 LCD Screen Replacement: Schritt 3, Bild 1 von 1
    • Lift off the back cover.
  4. BlackBerry 7510 LCD Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the two T6 screws.
  5. BlackBerry 7510 LCD Screen Replacement: Schritt 5, Bild 1 von 2 BlackBerry 7510 LCD Screen Replacement: Schritt 5, Bild 2 von 2
    • Remove the daughterboard.
    • Remove the exposed vibration motor.
  6. BlackBerry 7510 LCD Screen Replacement, LCD Screen: Schritt 6, Bild 1 von 1
    • Unscrew the screw holding the back plate.
  7. BlackBerry 7510 LCD Screen Replacement: Schritt 7, Bild 1 von 2 BlackBerry 7510 LCD Screen Replacement: Schritt 7, Bild 2 von 2
    • Carefully pry off front cover. Make sure the plastic clips are unlatched before applying force.
    • Lift off front cover from metal plate.
  8. BlackBerry 7510 LCD Screen Replacement: Schritt 8, Bild 1 von 1
    • Pry off the LCD screen with spudger at the two clips.
  9. BlackBerry 7510 LCD Screen Replacement: Schritt 9, Bild 1 von 2 BlackBerry 7510 LCD Screen Replacement: Schritt 9, Bild 2 von 2
    • Remove the LCD screen and replace it with a new one.
    • Careful not to rip the LCD ribbon.
Abschluss
Neil Johnson
12 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 14-44, Regan Winter 2010 Mitglied von Cal Poly, Team 14-44, Regan Winter 2010
CPSU-REGAN-W10S14G44
4 Mitglieder
8 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 2,577
