Zum Hauptinhalt wechseln
PlayStation One Lower Case Replacement
Was du brauchst
  1. PlayStation One Lower Case Replacement, Upper Case: Schritt 1, Bild 1 von 1
    • Remove all cables plugged into the PlayStation.
  2. PlayStation One Lower Case Replacement: Schritt 2, Bild 1 von 2 PlayStation One Lower Case Replacement: Schritt 2, Bild 2 von 2
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. PlayStation One Lower Case Replacement: Schritt 3, Bild 1 von 1
    • Flip the PlayStation back.
    • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
  4. PlayStation One Lower Case Replacement: Schritt 4, Bild 1 von 2 PlayStation One Lower Case Replacement: Schritt 4, Bild 2 von 2
    • Lift up and remove the upper case.
  5. PlayStation One Lower Case Replacement, Laser Assembly: Schritt 5, Bild 1 von 3 PlayStation One Lower Case Replacement, Laser Assembly: Schritt 5, Bild 2 von 3 PlayStation One Lower Case Replacement, Laser Assembly: Schritt 5, Bild 3 von 3
    • Disconnect the cables from the PSone’s board.
    • Take extreme care when disconnecting the ribbon cable from motherboard. You risk damaging the cable if you’re not careful.
  6. PlayStation One Lower Case Replacement, Mother Board: Schritt 6, Bild 1 von 2 PlayStation One Lower Case Replacement, Mother Board: Schritt 6, Bild 2 von 2
    • remove the metal plate
  7. PlayStation One Lower Case Replacement: Schritt 7, Bild 1 von 3 PlayStation One Lower Case Replacement: Schritt 7, Bild 2 von 3 PlayStation One Lower Case Replacement: Schritt 7, Bild 3 von 3
    • remove the mother board by lifting the back.
    • if you're having a hard time removing it, use your nail and lift the second controller port.
  8. PlayStation One Lower Case Replacement, Lower Case: Schritt 8, Bild 1 von 2 PlayStation One Lower Case Replacement, Lower Case: Schritt 8, Bild 2 von 2
    • Remove the metal case.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Marjorie
2.273 Reputation
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 54
Insgesamt: 3,999
