Zum Hauptinhalt wechseln
PlayStation One Mother Board Replacement
Was du brauchst
  1. PlayStation One Mother Board Replacement, Upper Case: Schritt 1, Bild 1 von 1
    • Remove all cables plugged into the PlayStation.
  2. PlayStation One Mother Board Replacement: Schritt 2, Bild 1 von 2 PlayStation One Mother Board Replacement: Schritt 2, Bild 2 von 2
    • Flip over the PlayStation and remove the six screws from the bottom.
  3. PlayStation One Mother Board Replacement: Schritt 3, Bild 1 von 1
    • Flip the PlayStation back.
    • There are no screws holding EVERYTHING inside the PlayStation so better hold it like a burger while flipping.
  4. PlayStation One Mother Board Replacement: Schritt 4, Bild 1 von 2 PlayStation One Mother Board Replacement: Schritt 4, Bild 2 von 2
    • Lift up and remove the upper case.
  5. PlayStation One Mother Board Replacement, Laser Assembly: Schritt 5, Bild 1 von 3 PlayStation One Mother Board Replacement, Laser Assembly: Schritt 5, Bild 2 von 3 PlayStation One Mother Board Replacement, Laser Assembly: Schritt 5, Bild 3 von 3
    • Disconnect the cables from the PSone’s board.
    • Take extreme care when disconnecting the ribbon cable from motherboard. You risk damaging the cable if you’re not careful.
  6. PlayStation One Mother Board Replacement, Mother Board: Schritt 6, Bild 1 von 2 PlayStation One Mother Board Replacement, Mother Board: Schritt 6, Bild 2 von 2
    • remove the metal plate
  7. PlayStation One Mother Board Replacement: Schritt 7, Bild 1 von 3 PlayStation One Mother Board Replacement: Schritt 7, Bild 2 von 3 PlayStation One Mother Board Replacement: Schritt 7, Bild 3 von 3
    • remove the mother board by lifting the back.
    • if you're having a hard time removing it, use your nail and lift the second controller port.
Abschluss
14 weitere Nutzer:innen haben diese Anleitung absolviert.
Marjorie
2.273 Reputation
11 Anleitungen geschrieben
Ein Kommentar
I think that the GPU in my PS One is going bad (screen flickers green and pink on occasion but it is becoming more frequent). Would replacing the motherboard fix this? That is, is the GPU stored on the motherboard?
Eric Rosenberg - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 3
Letzte 7 Tage: 26
Letzte 30 Tage: 139
Insgesamt: 11,322
