Zum Hauptinhalt wechseln
Snowboard Binding Replacement
Was du brauchst
  1. Snowboard Binding Replacement, Binding: Schritt 1, Bild 1 von 3 Snowboard Binding Replacement, Binding: Schritt 1, Bild 2 von 3 Snowboard Binding Replacement, Binding: Schritt 1, Bild 3 von 3
    • Release the binding straps by lifting up on the buckle and pulling towards the direction of the end of the ladder.
    • Not all binding straps will release the same way. If you are having trouble releasing your binding straps, please refer to your owner's manual.
  2. Snowboard Binding Replacement: Schritt 2, Bild 1 von 2 Snowboard Binding Replacement: Schritt 2, Bild 2 von 2
    • Move the straps and the highback plate out of the way in order to have clear access to the foot pad screw.
    • The highback plate is the vertical support plate located on the heel side of the binding.
  3. Snowboard Binding Replacement: Schritt 3, Bild 1 von 2 Snowboard Binding Replacement: Schritt 3, Bild 2 von 2
    • Use a #2 Phillips screwdriver to remove the panhead, 10mm wide, M4 x 12mm screw located in the middle of the foot pad.
  4. Snowboard Binding Replacement: Schritt 4, Bild 1 von 3 Snowboard Binding Replacement: Schritt 4, Bild 2 von 3 Snowboard Binding Replacement: Schritt 4, Bild 3 von 3
    • Use a #2 Phillips screwdriver to remove the four ovalhead M6 x 12mm screws that attach the base plate of the binding to the board.
    • Lift or slide the binding off the board and set the screws aside.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 17-4, Forte Winter 2014 Mitglied von Cal Poly, Team 17-4, Forte Winter 2014
CPSU-FORTE-W14S17G4
5 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 17
Letzte 30 Tage: 122
Insgesamt: 13,375
