Zum Hauptinhalt wechseln
HP Pavilion dv6-2158nr LCD Monitor Replacement
Was du brauchst
  1. HP Pavilion dv6-2158nr LCD Monitor Replacement, Battery: Schritt 1, Bild 1 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement, Battery: Schritt 1, Bild 2 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement, Battery: Schritt 1, Bild 3 von 3
    • Locate the battery on the bottom side of the laptop.
    • Slide the release switch and the battery will pop out.
    • Remove the battery
  2. HP Pavilion dv6-2158nr LCD Monitor Replacement, Keyboard: Schritt 2, Bild 1 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement, Keyboard: Schritt 2, Bild 2 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement, Keyboard: Schritt 2, Bild 3 von 3
    • Using a Philips #1 Loosen the three 7mm captive screws that secure the memory module compartment cover to the computer.
    • Lift the rear edge of the cover, swing it up and to the front, and remove the cover.
  3. HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 3, Bild 1 von 2 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 3, Bild 2 von 2
    • Loosen the two 6mm captive screws that secure the hard drive port bezel cover to the computer, using a Philips #1.
    • Lift the right side of the hard drive port bezel cover, swing it up and to the left, and remove the cover.
  4. HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 4, Bild 1 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 4, Bild 2 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 4, Bild 3 von 3
    • Use the Mylar tab to lift the hard drive up, and then slide it to the left to release it from the hard drive bay.
  5. HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 5, Bild 1 von 2 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 5, Bild 2 von 2
    • Disconnect the hard drive cable from the system board.
    • Remove the hard drive from the hard drive bay and set it aside.
  6. HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 6, Bild 1 von 2 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 6, Bild 2 von 2
    • With laptop upside down locate the three sets of screws that fasten the keyboard and switch cover.
    • Two Phillips 7mm screws that secure the switch cover to the computer.
    • Four Phillips 4.0mm screws that secure the switch cover to the computer. (these are inside the battery bay)
    • Four Philips 7mm screws that secure the keyboard to the computer.
    • Remove all ten screws.
  7. HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 7, Bild 1 von 2 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 7, Bild 2 von 2
    • Turn the computer over, and locate the Switch Cover.
    • Using the Safe Pry Tool, un-clip the Switch Cover until it detaches from the computer.
    • The clips will need careful prying to unhook.
  8. HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 8, Bild 1 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 8, Bild 2 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 8, Bild 3 von 3
    • Slide the Switch Cover onto the LCD Monitor, exposing the Speaker Assembly.
    • There are two ribbon cables still attached to the speaker assembly
    • Detach the two ribbon cables from the speaker assembly.
  9. HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 9, Bild 1 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 9, Bild 2 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 9, Bild 3 von 3
    • Remove the three silver Phillips 3.5mm screws that secure the keyboard to the computer.
    • Lift the rear edge of the keyboard and slide the keyboard back until the keyboard connector on the system board is accessible.
  10. HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 10, Bild 1 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 10, Bild 2 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 10, Bild 3 von 3
    • Unhinge the zero insertion force (ZIF) connector to release the ribbon cable then pull gently on the cable to release.
    • You need to unhinge the blue plastic to release the ribbon cable from the main board.
    • The keyboard can now be lifted off and set aside.
  11. HP Pavilion dv6-2158nr LCD Monitor Replacement, LCD Monitor: Schritt 11, Bild 1 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement, LCD Monitor: Schritt 11, Bild 2 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement, LCD Monitor: Schritt 11, Bild 3 von 3
    • Remove the 3mm screw that secures the WLAN module to the computer. (The edge of the module opposite the slot rises away from the computer.)
    • Remove the WLAN module by pulling it away from the slot at an angle.
    • Disconnect the two WLAN antenna cables from the WLAN module.
  12. HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 12, Bild 1 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 12, Bild 2 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 12, Bild 3 von 3
    • Disconnect the display panel cable by use pulling upward on cable tabs.
    • Disconnect the webcam/microphone cable from the system board.
    • Remove the WLAN antenna cables and the webcam/ microphone cable from the clips built into the top cover.
  13. HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 13, Bild 1 von 2 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 13, Bild 2 von 2
    • Remove the four Phillips 7mm screws that secure the display assembly to the computer.
    • Lift the display assembly straight up and remove it.
  14. HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 14, Bild 1 von 2 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 14, Bild 2 von 2
    • Remove the two Phillips 5mm screws that secure the display hinge to the display panel.
    • The screws are behind plastic stickers and are very easy to bend.
    • Use a prying tool to flex the plastic around the monitor display to release the clips holding the display case together.
    • Use caution when using prying tool and avoid damaging bezel clips.
  15. HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 15, Bild 1 von 1
    • Remove the display bezel to uncover the LCD display
    • Remove eight screws that fasten the LCD display.
    • two Phillips PM2.5×5.0 screws from the top corners.
    • six Phillips M2.5×5.0 screws from the display hinges
  16. HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 16, Bild 1 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 16, Bild 2 von 3 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 16, Bild 3 von 3
    • Flex the bottom of the display panel and release the display hinges
    • Place the LCD Monitor next to the display panel by flipping it over the display hinges.
    • Disconnect the display LED cable from the display panel cable and remove the display panel.
  17. HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 17, Bild 1 von 2 HP Pavilion dv6-2158nr LCD Monitor Replacement: Schritt 17, Bild 2 von 2
    • Using the Philips #1, Remove four 7mm screws from the LCD Monitor frame.
    • There are two screws on each side of the LCD Monitor.
    • Remove the LCD Monitor from the frame.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Chad
1.123 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 10-34, Maness Winter 2014 Mitglied von Cal Poly, Team 10-34, Maness Winter 2014
CPSU-MANESS-W14S10G34
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 21
Insgesamt: 6,457
