Zum Hauptinhalt wechseln
Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard
Was du brauchst
  1. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard, Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: Schritt 1, Bild 1 von 1
    • Insert wisdom here.
  2. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: Schritt 2, Bild 1 von 1
  3. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: Schritt 3, Bild 1 von 1
  4. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: Schritt 4, Bild 1 von 1
  5. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: Schritt 5, Bild 1 von 1
  6. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: Schritt 6, Bild 1 von 1
  7. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: Schritt 7, Bild 1 von 1
  8. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: Schritt 8, Bild 1 von 1
  9. Disassembling ZTE GRAND S FLEX : Unibody, Battery, Motherboard: Schritt 9, Bild 1 von 1
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Jonathan J
201 Reputation
1 Anleitung geschrieben
4 Kommentare
I tried to open the black part but has cracked with the minimum attempt. Now I have broken the front glass with the black part.
melchorct - Antwort
Historia, I cracked black glass (camera). where one can buy ? thanks
kamykazeandy -
same thing happened with me
but at least i was able to open it.
i have unplugged the battery fr long time but still not working, any suggestions???
nimer76 -
Same happened to me with the black camera cover. Do you guys found a replacement?
renehahn - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 10
Letzte 30 Tage: 10
Insgesamt: 7,405
