Zum Hauptinhalt wechseln
Canon EOS 300 Side Panel with Grip Replacement
Was du brauchst
  1. Canon EOS 300 Side Panel with Grip Replacement, Batteries: Schritt 1, Bild 1 von 3 Canon EOS 300 Side Panel with Grip Replacement, Batteries: Schritt 1, Bild 2 von 3 Canon EOS 300 Side Panel with Grip Replacement, Batteries: Schritt 1, Bild 3 von 3
    • Open up the battery door.
  2. Canon EOS 300 Side Panel with Grip Replacement: Schritt 2, Bild 1 von 2 Canon EOS 300 Side Panel with Grip Replacement: Schritt 2, Bild 2 von 2
    • Remove the batteries from the camera by sliding them out into your palm.
  3. Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Lever: Schritt 3, Bild 1 von 2 Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Lever: Schritt 3, Bild 2 von 2
    • Release the side latch to open the back panel.
  4. Canon EOS 300 Side Panel with Grip Replacement: Schritt 4, Bild 1 von 2 Canon EOS 300 Side Panel with Grip Replacement: Schritt 4, Bild 2 von 2
    • Remove the two black 4.5mm screws above and below the latch.
  5. Canon EOS 300 Side Panel with Grip Replacement: Schritt 5, Bild 1 von 2 Canon EOS 300 Side Panel with Grip Replacement: Schritt 5, Bild 2 von 2
    • Using your finger, carefully pry open the side panel from the top of camera.
    • Pull panel downwards to remove.
    • Make sure to keep track of the small black piece of rubber under the latch.
  6. Canon EOS 300 Side Panel with Grip Replacement, Front Panel: Schritt 6, Bild 1 von 2 Canon EOS 300 Side Panel with Grip Replacement, Front Panel: Schritt 6, Bild 2 von 2
    • Remove the two silver 6mm Phillips #1 screws.
  7. Canon EOS 300 Side Panel with Grip Replacement: Schritt 7, Bild 1 von 2 Canon EOS 300 Side Panel with Grip Replacement: Schritt 7, Bild 2 von 2
    • Flip camera over to the bottom.
    • Remove the one 5mm Phillips #1 silver screw.
  8. Canon EOS 300 Side Panel with Grip Replacement: Schritt 8, Bild 1 von 2 Canon EOS 300 Side Panel with Grip Replacement: Schritt 8, Bild 2 von 2
    • Remove the front panel by pulling away from the side with the lever.
  9. Canon EOS 300 Side Panel with Grip Replacement, Bottom Panel: Schritt 9, Bild 1 von 2 Canon EOS 300 Side Panel with Grip Replacement, Bottom Panel: Schritt 9, Bild 2 von 2
    • Remove three black 7.3mm Phillips #1 screws located on the corners of the camera.
    • Remove five black 4.8mm Phillips #1 screws.
  10. Canon EOS 300 Side Panel with Grip Replacement: Schritt 10, Bild 1 von 3 Canon EOS 300 Side Panel with Grip Replacement: Schritt 10, Bild 2 von 3 Canon EOS 300 Side Panel with Grip Replacement: Schritt 10, Bild 3 von 3
    • Simply remove the bottom panel by prying it off with your finger.
    • When removing the panel, be sure the bottom of the camera is facing upright. There are loose gears that may fall out.
    • Be wary of a loose piece of foam attached to the bottom panel.
  11. Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Grip: Schritt 11, Bild 1 von 3 Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Grip: Schritt 11, Bild 2 von 3 Canon EOS 300 Side Panel with Grip Replacement, Side Panel with Grip: Schritt 11, Bild 3 von 3
    • Remove the remote control socket cover.
  12. Canon EOS 300 Side Panel with Grip Replacement: Schritt 12, Bild 1 von 2 Canon EOS 300 Side Panel with Grip Replacement: Schritt 12, Bild 2 von 2
    • Remove two black 4.5mm Phillips #1 screws.
  13. Canon EOS 300 Side Panel with Grip Replacement: Schritt 13, Bild 1 von 2 Canon EOS 300 Side Panel with Grip Replacement: Schritt 13, Bild 2 von 2
    • Remove two black 4.8mm Phillips #1 screws on the front of the camera.
  14. Canon EOS 300 Side Panel with Grip Replacement: Schritt 14, Bild 1 von 2 Canon EOS 300 Side Panel with Grip Replacement: Schritt 14, Bild 2 von 2
    • Pry open the side grip using a spudger.
Abschluss
Jordan Tang
590 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 6-20, Maness Winter 2014 Mitglied von Cal Poly, Team 6-20, Maness Winter 2014
CPSU-MANESS-W14S6G20
4 Mitglieder
32 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 9
Letzte 30 Tage: 19
Insgesamt: 898
