Zum Hauptinhalt wechseln
Imation Superdisk USB Drive Plastic Housing Replacement
Was du brauchst
  1. Imation Superdisk USB Drive Plastic Housing Replacement, Plastic Housing: Schritt 1, Bild 1 von 2 Imation Superdisk USB Drive Plastic Housing Replacement, Plastic Housing: Schritt 1, Bild 2 von 2
    • Flip the device over so the bottom is facing up.
    • You will know it is the bottom because there will be six silver screws visible.
  2. Imation Superdisk USB Drive Plastic Housing Replacement: Schritt 2, Bild 1 von 2 Imation Superdisk USB Drive Plastic Housing Replacement: Schritt 2, Bild 2 von 2
    • Remove the USB converter device by gently pulling it out.
    • Do not pull the converter device out by the cord.
  3. Imation Superdisk USB Drive Plastic Housing Replacement: Schritt 3, Bild 1 von 2 Imation Superdisk USB Drive Plastic Housing Replacement: Schritt 3, Bild 2 von 2
    • Remove the six silver screws using a small Phillips head screwdriver.
  4. Imation Superdisk USB Drive Plastic Housing Replacement: Schritt 4, Bild 1 von 2 Imation Superdisk USB Drive Plastic Housing Replacement: Schritt 4, Bild 2 von 2
    • Slide the bottom plastic panel of the shell down so it is free of the end cap and the top panel.
    • Lift panel free of device.
  5. Imation Superdisk USB Drive Plastic Housing Replacement: Schritt 5, Bild 1 von 2 Imation Superdisk USB Drive Plastic Housing Replacement: Schritt 5, Bild 2 von 2
    • Remove the plastic end cap by sliding it forward, freeing from the rest of the device.
    • You can identify the end cap by noting the label "SuperDisk Drive" above where you would insert a floppy disk.
  6. Imation Superdisk USB Drive Plastic Housing Replacement: Schritt 6, Bild 1 von 2 Imation Superdisk USB Drive Plastic Housing Replacement: Schritt 6, Bild 2 von 2
    • Slide the metal housing out of the plastic shell.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Ohio State, Team 1-2, Buehl Spring 2014 Mitglied von Ohio State, Team 1-2, Buehl Spring 2014
OSU-BUEHL-S14S1G2
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 9
Letzte 30 Tage: 19
Insgesamt: 818
