Zum Hauptinhalt wechseln
Pantech CDM8975 Keyboard Replacement
Was du brauchst
  1. Pantech CDM8975 Keyboard Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Remove the battery.
    • Remove four Phillips screws.
  2. Pantech CDM8975 Keyboard Replacement: Schritt 2, Bild 1 von 1
    • Pry up the plastic layer with a plastic opening tool.
    • NOTE: Be careful that you do not separate the two plastic parts completely they are fragile and may break if pulled too hard.
  3. Pantech CDM8975 Keyboard Replacement, Remove Keyboard: Schritt 3, Bild 1 von 1
    • Slide out the keyboard carefully in between the two layers.
  4. Pantech CDM8975 Keyboard Replacement: Schritt 4, Bild 1 von 1
    • Insert the new keyboard in between the two layers carefully.
  5. Pantech CDM8975 Keyboard Replacement: Schritt 5, Bild 1 von 1
    • Check if the edges are perfectly aligned between the two plastic layers after you insert the keyboard.
  6. Pantech CDM8975 Keyboard Replacement: Schritt 6, Bild 1 von 1
    • Press the two plastic layers back together.
    • Reinsert the four screws and place the battery and cover back.
Abschluss
You now have a new keyboard.
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Richard
116 Reputation
1 Anleitung geschrieben
Ohio State, Team 1-4, Meza Spring 2014 Mitglied von Ohio State, Team 1-4, Meza Spring 2014
OSU-MEZA-S14S1G4
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 13
Insgesamt: 257
