Zum Hauptinhalt wechseln
Dell Latitude D620 CD Drive Replacement
Was du brauchst
  1. Dell Latitude D620 CD Drive Replacement, Keyboard: Schritt 1, Bild 1 von 1
    • Power down the laptop and remove the battery.
    • Open the laptop cover all of the way.
  2. Dell Latitude D620 CD Drive Replacement: Schritt 2, Bild 1 von 3 Dell Latitude D620 CD Drive Replacement: Schritt 2, Bild 2 von 3 Dell Latitude D620 CD Drive Replacement: Schritt 2, Bild 3 von 3
    • Locate the notch under the cover at the top of the keyboard
    • Using the spudger as a lever, lift the plastic covering
    • Carefully remove the rest of the covering from right to left
  3. Dell Latitude D620 CD Drive Replacement: Schritt 3, Bild 1 von 1
    • Unscrew the top portion of the keyboard using a #00 screwdriver
  4. Dell Latitude D620 CD Drive Replacement: Schritt 4, Bild 1 von 1
    • Hold keyboard from the top and gently pull towards the LCD screen to remove the keyboard from the case
    • Don't pull on the keyboard too forcefully because it is attached to the motherboard with a short, thin ribbon cable
  5. Dell Latitude D620 CD Drive Replacement: Schritt 5, Bild 1 von 2 Dell Latitude D620 CD Drive Replacement: Schritt 5, Bild 2 von 2
    • Once keyboard is out of the case, lay it face-down on the track pad
  6. Dell Latitude D620 CD Drive Replacement: Schritt 6, Bild 1 von 2 Dell Latitude D620 CD Drive Replacement: Schritt 6, Bild 2 von 2
    • Using a small spudger, pull back on the black bar to release the blue lever
  7. Dell Latitude D620 CD Drive Replacement: Schritt 7, Bild 1 von 1
    • Pull up on the metal bar connected to the socket to detach the ribbon cable
  8. Dell Latitude D620 CD Drive Replacement, CD Drive: Schritt 8, Bild 1 von 2 Dell Latitude D620 CD Drive Replacement, CD Drive: Schritt 8, Bild 2 von 2
    • Press in the tab on the bottom right side of the CD drive
    • The tab comes out on its own; there is no need to pull it out manually.
  9. Dell Latitude D620 CD Drive Replacement: Schritt 9, Bild 1 von 1
    • Gently pull the tab to remove the disk tray.
Abschluss
10 weitere Nutzer:innen haben diese Anleitung absolviert.
Ivan
194 Reputation
1 Anleitung geschrieben
Cal Poly, Team 24-35, Regan Spring 2010 Mitglied von Cal Poly, Team 24-35, Regan Spring 2010
CPSU-REGAN-S10S24G35
4 Mitglieder
4 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 8,364
