Zum Hauptinhalt wechseln
Toshiba Satellite L455D-S5976 Optical Drive Replacement
Was du brauchst
  1. Toshiba Satellite L455D-S5976 Optical Drive Replacement, Battery: Schritt 1, Bild 1 von 1
    • Unlock the right tab by sliding it to the right with your finger.
  2. Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 2, Bild 1 von 1
    • Hold the left tab to the left using your left hand.
  3. Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery by placing your finger in the middle groove and lifting up.
  4. Toshiba Satellite L455D-S5976 Optical Drive Replacement, Optical Drive: Schritt 4, Bild 1 von 1
    • Remove the 13 Phillips #1 10mm screws from the backside of your computer using a Phillips #1 screwdriver.
  5. Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 5, Bild 1 von 1
    • Remove the two Phillips #1 6mm screws from the backside of your computer using a Phillips #1 screwdriver.
  6. Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 6, Bild 1 von 1
    • Remove the three 3mm screws from beneath the battery with a Phillips #1 screwdriver.
  7. Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 7, Bild 1 von 1
    • Lift up the corner panel and remove it with your hand.
  8. Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 8, Bild 1 von 1
    • Unscrew the four Phillips #1 3mm using a Phillips #1 screwdriver.
    • Unscrew the four 10mm screws around hard drive using a Phillips #1 screwdriver.
  9. Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 9, Bild 1 von 2 Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 9, Bild 2 von 2
    • To remove the hard drive case, first pull the black tab to the right.
    • Then pull the black tab up to remove the case.
  10. Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 10, Bild 1 von 3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 10, Bild 2 von 3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 10, Bild 3 von 3
    • Remove the plastic strip above the "F" keys using the spudger by placing the small end of the spudger under the strip and lifting up.
  11. Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 11, Bild 1 von 1
    • Remove the two Phillips #1 3mm screws underneath the plastic strip using a Phillips #1 screwdriver.
  12. Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 12, Bild 1 von 1
    • Lift the keyboard up and remove it with your hands.
  13. Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 13, Bild 1 von 1
    • Remove the five Phillips #1 10mm screws underneath the keyboard using a Phillips #1 screwdriver.
  14. Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 14, Bild 1 von 3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 14, Bild 2 von 3 Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 14, Bild 3 von 3
    • Lift up the plastic panel and carefully disconnect the red and white ports.
    • Remove the panel
  15. Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 15, Bild 1 von 1
    • Turn the laptop over so the bottom is facing up
    • Then remove the 3mm screw with a #1 screwdriver, located underneath the panel containing the wifi card and RAM
  16. Toshiba Satellite L455D-S5976 Optical Drive Replacement: Schritt 16, Bild 1 von 1
    • Turn the laptop back over so the motherboard is facing up
    • Now slide the optical drive out of the computer by gently pulling it to the right
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
NateJohnson
1.047 Reputation
5 Anleitungen geschrieben
Cal Poly, Team 9-26, Maness Winter 2014 Mitglied von Cal Poly, Team 9-26, Maness Winter 2014
CPSU-MANESS-W14S9G26
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 13
Insgesamt: 1,156
