Zum Hauptinhalt wechseln
Mr. Coffee DW13 O Ring Replacement
Was du brauchst
  1. Mr. Coffee DW13 O Ring Replacement, Base: Schritt 1, Bild 1 von 2 Mr. Coffee DW13 O Ring Replacement, Base: Schritt 1, Bild 2 von 2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 O Ring Replacement: Schritt 2, Bild 1 von 2 Mr. Coffee DW13 O Ring Replacement: Schritt 2, Bild 2 von 2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 O Ring Replacement: Schritt 3, Bild 1 von 1
    • Gently lift the base cover to expose the inside of the coffee machine.
  4. Mr. Coffee DW13 O Ring Replacement, O Ring: Schritt 4, Bild 1 von 2 Mr. Coffee DW13 O Ring Replacement, O Ring: Schritt 4, Bild 2 von 2
    • Remove the two 13mm screws securing the silver support bracket using a #2 Phillips head screwdriver.
  5. Mr. Coffee DW13 O Ring Replacement: Schritt 5, Bild 1 von 1
    • Gently lift the silver support bracket freeing the heating plate from the heating coil.
  6. Mr. Coffee DW13 O Ring Replacement: Schritt 6, Bild 1 von 2 Mr. Coffee DW13 O Ring Replacement: Schritt 6, Bild 2 von 2
    • Use needle-nose pilers to pinch and loosen the crimps
  7. Mr. Coffee DW13 O Ring Replacement: Schritt 7, Bild 1 von 1
    • Once the crimps are loosened, slide them down the tubing.
  8. Mr. Coffee DW13 O Ring Replacement: Schritt 8, Bild 1 von 2 Mr. Coffee DW13 O Ring Replacement: Schritt 8, Bild 2 von 2
    • Separate the tubing from the heating coil by grasping the tubing in one hand and the heating coil in the other and gently pulling apart.
  9. Mr. Coffee DW13 O Ring Replacement: Schritt 9, Bild 1 von 2 Mr. Coffee DW13 O Ring Replacement: Schritt 9, Bild 2 von 2
    • Place one of your hands on the front side of the heating plate.
    • Use this hand to gently push the heating plate towards yourself and out of the machine.
  10. Mr. Coffee DW13 O Ring Replacement: Schritt 10, Bild 1 von 2 Mr. Coffee DW13 O Ring Replacement: Schritt 10, Bild 2 von 2
    In diesem Schritt verwendetes Werkzeug:
    Flathead 3/32" or 2.5 mm Screwdriver
    $5.49
    Kaufen
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 10-31, Maness Winter 2014 Mitglied von Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 4
Insgesamt: 1,014
