Einleitung
The bottom of your Roomba can be easily removed by just removing the side brush, unscrewing four screws, and separating the plate from the device.
Was du brauchst
While holding the side brush in place, use a Phillips #1 screwdriver to remove the 4.5mm screw from the center of the brush.
Rotate the Roomba upside-down so the bottom is facing towards you.
Using a Phillips #2 screwdriver, remove the captive screws that hold the bottom plate in place.
