Einleitung
This guide shows how to replace the LCD screen on the Samsung L100.
Was du brauchst
Remove the six external screws from the camera using a Phillips #0 screwdriver.
After the screws has been removed, the bottom of the back half of the external case should be loosened from the camera.
Open the battery cover that's located on the bottom right side of the camera and carefully remove the battery.
Slide your fingernail or a plastic spudger in the groove from the bottom to the top right side of the camera.
Carefully squeeze the top right corner of the camera and pry off the external cover.
Continue to pull the external cover and it will come off cleanly.
Remove the screws holding the circuit board.
Carefully remove the circuit board.
Remove the green tape that holds the LCD screen.
Carefully lift the LCD Screen.
Flip the camera over to the other side.
Lift the black strip and the ribbon should easily come out.
The LCD Screen should be completely separated from the camera now.
Insert the new LCD Screen by pushing the ribbon into the slot.
Flip the black strip back down to lock the ribbon in.
Your new LCD Screen should be connected to the camera now.
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
