Zum Hauptinhalt wechseln
Disassembling Kodak Easyshare C813 Back Cover
Was du brauchst
  1. Disassembling Kodak Easyshare C813 Back Cover, Battery: Schritt 1, Bild 1 von 1
    • Turn off camera by firmly pressing the power button that is located on the top of the camera near the selector dial.
  2. Disassembling Kodak Easyshare C813 Back Cover: Schritt 2, Bild 1 von 3 Disassembling Kodak Easyshare C813 Back Cover: Schritt 2, Bild 2 von 3 Disassembling Kodak Easyshare C813 Back Cover: Schritt 2, Bild 3 von 3
    • Press thumb firmly on battery door and slide it in the direction of the arrow.
    • Lift thumb allowing the door to swing open.
  3. Disassembling Kodak Easyshare C813 Back Cover, Back Cover: Schritt 3, Bild 1 von 1
    In diesem Schritt verwendetes Werkzeug:
    Anti-Static Wrist Strap
    $7.95
    Kaufen
  4. Disassembling Kodak Easyshare C813 Back Cover: Schritt 4, Bild 1 von 1
    • Turn the camera off by firmly pressing the power button located on top of the camera.
  5. Disassembling Kodak Easyshare C813 Back Cover: Schritt 5, Bild 1 von 3 Disassembling Kodak Easyshare C813 Back Cover: Schritt 5, Bild 2 von 3 Disassembling Kodak Easyshare C813 Back Cover: Schritt 5, Bild 3 von 3
    • Locate the 7 screws holding the back cover on.
    • Three screws are located on the bottom of the camera.
    • Two screws are located on the side shown in the photograph.
    • Two final screws are located on the opposite side shown in the photograph.
  6. Disassembling Kodak Easyshare C813 Back Cover: Schritt 6, Bild 1 von 3 Disassembling Kodak Easyshare C813 Back Cover: Schritt 6, Bild 2 von 3 Disassembling Kodak Easyshare C813 Back Cover: Schritt 6, Bild 3 von 3
    Phillips #00 Screwdriver
    $5.49
    Kaufen
    • Remove all 7 screws:
    • Hold the camera firmly with one hand so that you can still see a screw.
    • Place the Philips 00(Found here)screwdriver into the screw.
    • Turn the screwdriver to the left until it is free.
    • Repeat for the remaining screws.
  7. Disassembling Kodak Easyshare C813 Back Cover: Schritt 7, Bild 1 von 3 Disassembling Kodak Easyshare C813 Back Cover: Schritt 7, Bild 2 von 3 Disassembling Kodak Easyshare C813 Back Cover: Schritt 7, Bild 3 von 3
    • Use plastic opening tools to slightly open the side of the case.
    • Insert a plastic opening tool and apply pressure to the internal three tabs at the top.
    • The first two are near the words "3X Optical Zoom".
    • The third is near the shutter button.
  8. Disassembling Kodak Easyshare C813 Back Cover: Schritt 8, Bild 1 von 3 Disassembling Kodak Easyshare C813 Back Cover: Schritt 8, Bild 2 von 3 Disassembling Kodak Easyshare C813 Back Cover: Schritt 8, Bild 3 von 3
    • Gently pull apart the back cover from the rest of the camera.
    • Make sure there are no more screws or tabs keeping the cover on.
    • Use the plastic opening tool to separate any sides still closely connected.
Ziellinie
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Susan Marano
336 Reputation
7 Anleitungen geschrieben
Cal Poly, Team 24-22, Regan Spring 2010 Mitglied von Cal Poly, Team 24-22, Regan Spring 2010
CPSU-REGAN-S10S24G22
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 4
Insgesamt: 2,366
