Zum Hauptinhalt wechseln
Xbox 360 E Front Panel Replacement
Was du brauchst
  1. Xbox 360 E Front Panel Replacement, Front Panel: Schritt 1, Bild 1 von 3 Xbox 360 E Front Panel Replacement, Front Panel: Schritt 1, Bild 2 von 3 Xbox 360 E Front Panel Replacement, Front Panel: Schritt 1, Bild 3 von 3
    • In front of the CD drive you will find the Xbox logo. Press on the area left of the Xbox logo, and the disk tray panel will pop off.
  2. Xbox 360 E Front Panel Replacement: Schritt 2, Bild 1 von 3 Xbox 360 E Front Panel Replacement: Schritt 2, Bild 2 von 3 Xbox 360 E Front Panel Replacement: Schritt 2, Bild 3 von 3
    • Beginning on the left side without the grate, run the spudger along the crevice until you've reached the grated part, while holding the part that's being separated as you go.
  3. Xbox 360 E Front Panel Replacement: Schritt 3, Bild 1 von 3 Xbox 360 E Front Panel Replacement: Schritt 3, Bild 2 von 3 Xbox 360 E Front Panel Replacement: Schritt 3, Bild 3 von 3
    • Keep holding the partially separated panel open. It's easiest to do this by wedging a spudger into the opening but can also be held open by your hands.
    • Rotate the Xbox to the left to locate the clip connecting the front panel to the body. Insert the spudger inside the gap to release the clip. This may require wiggling the spudger. The clip will pop off, making the front panel looser.
  4. Xbox 360 E Front Panel Replacement: Schritt 4, Bild 1 von 3 Xbox 360 E Front Panel Replacement: Schritt 4, Bild 2 von 3 Xbox 360 E Front Panel Replacement: Schritt 4, Bild 3 von 3
    • Flip the Xbox so the opposite side is towards you. Make sure to keep the separation open.
    • Locate the other clip and insert the spudger to remove it.
  5. Xbox 360 E Front Panel Replacement: Schritt 5, Bild 1 von 2 Xbox 360 E Front Panel Replacement: Schritt 5, Bild 2 von 2
    • Continue to run the spudger along the crease to release any further clips that may still be attatched.
    • Do not pull off the panel too fast because you don't want to damage the ribbon cable. Slowly pull away the panel.
    • Now that the front panel has been released from its clips you can pull off the front panel.
  6. Xbox 360 E Front Panel Replacement: Schritt 6, Bild 1 von 3 Xbox 360 E Front Panel Replacement: Schritt 6, Bild 2 von 3 Xbox 360 E Front Panel Replacement: Schritt 6, Bild 3 von 3
    • Find the brown section where the ribbon cable enters the green board. Flip the brown part up and pull out the plastic tab at the end of the ribbon.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Sarah
1.726 Reputation
4 Anleitungen geschrieben
Cal Poly, Team 2-11, Amido Winter 2014 Mitglied von Cal Poly, Team 2-11, Amido Winter 2014
CPSU-AMIDO-W14S2G11
4 Mitglieder
43 Anleitungen geschrieben
Ein Kommentar
Where can I find a new ribbon cable for Xbox 360 e? In addition, can very minuscule damage to cable cause the power button to turn red?
braxton.taylor25 - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 10
Letzte 30 Tage: 58
Insgesamt: 5,870
