Zum Hauptinhalt wechseln
Triace A310 Disk Brake Replacement
Was du brauchst
  1. Triace A310 Disk Brake Replacement, Tire: Schritt 1, Bild 1 von 1
    • Begin loosening the tire by turning the quick release handle.
  2. Triace A310 Disk Brake Replacement: Schritt 2, Bild 1 von 2 Triace A310 Disk Brake Replacement: Schritt 2, Bild 2 von 2
    • Gripping the rear derailleur, pull the arm back, away from the front of the bike.
    • Notice how the derailleur becomes almost vertical in the second picture when compared to the first.
  3. Triace A310 Disk Brake Replacement: Schritt 3, Bild 1 von 2 Triace A310 Disk Brake Replacement: Schritt 3, Bild 2 von 2
    • There should be enough slack, in the chain, at this point to remove the tire from the bike.
    • Note: You may need to wiggle the tire and chain around in order to create enough slack.
    • Remove the tire from the bike.
  4. Triace A310 Disk Brake Replacement, Disk Brake: Schritt 4, Bild 1 von 1
    • Place the tire flat on the ground making sure the disk is facing you.
  5. Triace A310 Disk Brake Replacement: Schritt 5, Bild 1 von 3 Triace A310 Disk Brake Replacement: Schritt 5, Bild 2 von 3 Triace A310 Disk Brake Replacement: Schritt 5, Bild 3 von 3
    • Using the modular screw driver with a T25 bit, begin loosening and then removing the six 10mm-long screws.
    • Make sure to keep track of all of the removed pieces.
  6. Triace A310 Disk Brake Replacement: Schritt 6, Bild 1 von 2 Triace A310 Disk Brake Replacement: Schritt 6, Bild 2 von 2
    • After all of the screws have been removed, take the disk and pull it away from the tire.
Abschluss
Daniel
222 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 1-37, Maness Winter 2014 Mitglied von Cal Poly, Team 1-37, Maness Winter 2014
CPSU-MANESS-W14S1G37
4 Mitglieder
11 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 6
Letzte 30 Tage: 12
Insgesamt: 600
