Zum Hauptinhalt wechseln
Mr. Coffee DW13 Power Cord Replacement
Was du brauchst
  1. Mr. Coffee DW13 Power Cord Replacement, Base: Schritt 1, Bild 1 von 2 Mr. Coffee DW13 Power Cord Replacement, Base: Schritt 1, Bild 2 von 2
    • Before performing this repair, be sure that your machine is unplugged and dry and that your work space is clean.
    • Flip the Mr. Coffee DW13 over so that the lid is facing away from you and the base is facing toward you.
  2. Mr. Coffee DW13 Power Cord Replacement: Schritt 2, Bild 1 von 2 Mr. Coffee DW13 Power Cord Replacement: Schritt 2, Bild 2 von 2
    • Remove the eight 11 mm screws that secure the base of the machine with a Phillips Head #2 screwdriver.
  3. Mr. Coffee DW13 Power Cord Replacement: Schritt 3, Bild 1 von 1
    • Gently lift the base cover to expose the inside of the coffee machine.
  4. Mr. Coffee DW13 Power Cord Replacement, Power Cord: Schritt 4, Bild 1 von 2 Mr. Coffee DW13 Power Cord Replacement, Power Cord: Schritt 4, Bild 2 von 2
    • Locate the white tab that covers and holds the power cord in place. It has two screws on either side of it.
    • Use a #2 Philips Head screwdriver to unscrew the two 13mm screws holding the tab in place.
  5. Mr. Coffee DW13 Power Cord Replacement: Schritt 5, Bild 1 von 2 Mr. Coffee DW13 Power Cord Replacement: Schritt 5, Bild 2 von 2
    • Gently lift up on the white tab, removing it from the coffee machine.
  6. Mr. Coffee DW13 Power Cord Replacement: Schritt 6, Bild 1 von 2 Mr. Coffee DW13 Power Cord Replacement: Schritt 6, Bild 2 von 2
    • Locate the 2 electrical connectors running from the black plastic-coated power cord to the interior of the power switch.
    • One cord is copper colored and ends at the power switch in a silver metal square.
    • The other cord is white and ends at the power switch in a black plastic square.
  7. Mr. Coffee DW13 Power Cord Replacement: Schritt 7, Bild 1 von 2 Mr. Coffee DW13 Power Cord Replacement: Schritt 7, Bild 2 von 2
    • Grasp the copper cord close to the power switch. Lightly pull the silver end tab from the end to detach it.
  8. Mr. Coffee DW13 Power Cord Replacement: Schritt 8, Bild 1 von 2 Mr. Coffee DW13 Power Cord Replacement: Schritt 8, Bild 2 von 2
    • Lightly pull the white cord away from the power switch by grasping the black plastic-coated head.
    • There are two white cords attached to each other. Pull them apart by grasping the different black heads and separating them.
  9. Mr. Coffee DW13 Power Cord Replacement: Schritt 9, Bild 1 von 3 Mr. Coffee DW13 Power Cord Replacement: Schritt 9, Bild 2 von 3 Mr. Coffee DW13 Power Cord Replacement: Schritt 9, Bild 3 von 3
    • Pull the power cord through the hole at the back of the base of the machine, followed by the two colored cords.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Tess Bradley
373 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 10-31, Maness Winter 2014 Mitglied von Cal Poly, Team 10-31, Maness Winter 2014
CPSU-MANESS-W14S10G31
4 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 35
Insgesamt: 3,190
