Zum Hauptinhalt wechseln
Memorex Mi3X Minimove Display Replacement
Was du brauchst
  1. Memorex Mi3X Minimove Display Replacement, Back Panel: Schritt 1, Bild 1 von 1
    • Remove the two plastic screw covers on the back of your Minimove by inserting the flat end of your plastic opening tool between the screw cover and the back panel and prying it out.
    • It may be helpful to pull the plastic covers out with your fingers once the top of the cover has been revealed by using the plastic opening tool.
  2. Memorex Mi3X Minimove Display Replacement: Schritt 2, Bild 1 von 1
    • This step will require at least a 30 mm Phillips #1 screwdriver.
    • Use a Phillips #1 screwdriver to remove the two 12 mm screws.
  3. Memorex Mi3X Minimove Display Replacement: Schritt 3, Bild 1 von 1
    • The bottom panel screws and screw covers must be removed in order to access the back panel.
    • Remove the four grey screw covers by inserting the plastic opening tool underneath the screw covers and rotating around the circumference.
    • The adhesive on the screw covers should be sticky enough to put the covers back on when re-assembling the device.
  4. Memorex Mi3X Minimove Display Replacement: Schritt 4, Bild 1 von 1
    • Remove the two 8 mm screws with a Phillips #1 screwdriver.
    • Remove the two 12 mm screws with a long Phillips #1 screwdriver.
  5. Memorex Mi3X Minimove Display Replacement: Schritt 5, Bild 1 von 2 Memorex Mi3X Minimove Display Replacement: Schritt 5, Bild 2 von 2
    • To remove the back panel, use the plastic opening tool and gently work around the outline of the panel. The outline wraps around the sides and can be spotted at the top back of the device.
  6. Memorex Mi3X Minimove Display Replacement: Schritt 6, Bild 1 von 3 Memorex Mi3X Minimove Display Replacement: Schritt 6, Bild 2 von 3 Memorex Mi3X Minimove Display Replacement: Schritt 6, Bild 3 von 3
    • Be careful not to use too much force to remove the panel. The antenna wire is connected to the inside of the panel and may be damaged or ripped off if the panel is not gently removed.
    • After loosening the panel with the plastic opening tool, use moderate force to pry open the panel with your hands.
    • Carefully pull the panel off.
  7. Memorex Mi3X Minimove Display Replacement: Schritt 7, Bild 1 von 1
    • Use a Phillips #1 screwdriver to detach the wire from the back panel by removing the 8 mm screw connecting the wire to the antenna.
  8. Memorex Mi3X Minimove Display Replacement: Schritt 8, Bild 1 von 2 Memorex Mi3X Minimove Display Replacement: Schritt 8, Bild 2 von 2
    • If desired, the antenna can now be removed by pulling inwards and horizontal to the panel bottom.
  9. Memorex Mi3X Minimove Display Replacement: Schritt 9, Bild 1 von 1
    • Use the Phillips #1 screwdriver to remove the four 12 mm screws.
    • Remove the five 6 mm screws at the top with the same screwdriver.
  10. Memorex Mi3X Minimove Display Replacement: Schritt 10, Bild 1 von 1
    • Use a Phillips #1 screwdriver and remove the two vertical 8 mm screws from the top.
  11. Memorex Mi3X Minimove Display Replacement: Schritt 11, Bild 1 von 2 Memorex Mi3X Minimove Display Replacement: Schritt 11, Bild 2 von 2
    • Pry open the inner back panel by inserting the plastic opening tool in the crack at the top corner.
    • Use moderate force to pry it open and take the cover off.
  12. Memorex Mi3X Minimove Display Replacement, iPod Adapter: Schritt 12, Bild 1 von 3 Memorex Mi3X Minimove Display Replacement, iPod Adapter: Schritt 12, Bild 2 von 3 Memorex Mi3X Minimove Display Replacement, iPod Adapter: Schritt 12, Bild 3 von 3
    • Be careful when removing the bottom panel. The plastic tab that runs alongside the right speaker between the upper brown radio motherboard and the lower green audio daughterboard may damage the device if the bottom panel is removed improperly.
    • Remove the bottom panel of the boombox by carefully pulling the panel straight backwards from the boombox until the boards are free.
  13. Memorex Mi3X Minimove Display Replacement: Schritt 13, Bild 1 von 2 Memorex Mi3X Minimove Display Replacement: Schritt 13, Bild 2 von 2
    • Use a Phillips #1 screwdriver to remove the two 8 mm screws encasing the iPod adapter near the top of the device.
  14. Memorex Mi3X Minimove Display Replacement: Schritt 14, Bild 1 von 2 Memorex Mi3X Minimove Display Replacement: Schritt 14, Bild 2 von 2
    • Use moderate force to pry the plastic casing off with your finger while pushing with your thumb against the black, round capacitors.
  15. Memorex Mi3X Minimove Display Replacement: Schritt 15, Bild 1 von 3 Memorex Mi3X Minimove Display Replacement: Schritt 15, Bild 2 von 3 Memorex Mi3X Minimove Display Replacement: Schritt 15, Bild 3 von 3
    • Follow the wires attaching to the iPod adapter and use the IC (Integrated Circuit) extractor to remove the indicated wire connectors from the motherboard.
    • Pinch the IC extractor just under the top lip of the wire housing.
  16. Memorex Mi3X Minimove Display Replacement: Schritt 16, Bild 1 von 2 Memorex Mi3X Minimove Display Replacement: Schritt 16, Bild 2 von 2
    • Going back to the small green daughterboard, unscrew the four 6 mm screws with a Phillips #1 screwdriver.
  17. Memorex Mi3X Minimove Display Replacement: Schritt 17, Bild 1 von 1
    • Remove the iPod adapter by sliding it out of the slot.
  18. Memorex Mi3X Minimove Display Replacement, Display: Schritt 18, Bild 1 von 2 Memorex Mi3X Minimove Display Replacement, Display: Schritt 18, Bild 2 von 2
    • Locate and unscrew the four 8mm screws (in red) along the edge with a Phillips #1 screwdriver.
    • Unscrew the two 12mm screws (in orange) on the inside of the daughterboard.
  19. Memorex Mi3X Minimove Display Replacement: Schritt 19, Bild 1 von 1
    • Slide out the iPod adapter housing by applying moderate pressure with your two index fingers from the inside as well as your thumb downward.
  20. Memorex Mi3X Minimove Display Replacement: Schritt 20, Bild 1 von 2 Memorex Mi3X Minimove Display Replacement: Schritt 20, Bild 2 von 2
    • Remove the four 8 mm screws using a Phillips #1 screwdriver.
  21. Memorex Mi3X Minimove Display Replacement: Schritt 21, Bild 1 von 2 Memorex Mi3X Minimove Display Replacement: Schritt 21, Bild 2 von 2
    • The speaker housing may require more force than expected to remove because it is held together by a thin layer of rubber. Do not be afraid of using more force if you are unable to remove it on the first try.
    • When the housing is removed the rubber adhesive will come off. This should not effect your device's functionality in any way.
    • Grab the outside of one speaker housing and pull outwards (starting with the top) while holding the main casing still with your other hand.
    • Remove the other housing on the opposite side the same way.
  22. Memorex Mi3X Minimove Display Replacement: Schritt 22, Bild 1 von 2 Memorex Mi3X Minimove Display Replacement: Schritt 22, Bild 2 von 2
    • Be careful when removing the daughterboard. There are still two wires connecting the display daughterboard to the radio motherboard which can be damaged or ripped if recklessly removed.
    • Gently lift the display daughterboard straight up and remove it from the case.
  23. Memorex Mi3X Minimove Display Replacement: Schritt 23, Bild 1 von 2 Memorex Mi3X Minimove Display Replacement: Schritt 23, Bild 2 von 2
    • To finish, disconnect the two wires outlined in red rectangles that are connected to the motherboard using the IC extractor.
    • Pinch the IC extractor just under the top lip of the wire housing and pull firmly out.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 2-9, Amido Winter 2014 Mitglied von Cal Poly, Team 2-9, Amido Winter 2014
CPSU-AMIDO-W14S2G9
5 Mitglieder
6 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 11
Insgesamt: 550
