Zum Hauptinhalt wechseln
HP rp5700 Hard Drive Replacement
  1. HP rp5700 Hard Drive Replacement, Cover Removal: Schritt 1, Bild 1 von 1
    • Make sure the computer is unplugged.
    • Be sure to touch any metal surface with your hand to discharge any static electricity that might have built up.
    • Make sure all auxiliary cords are disconnected from the desktop. If not, remove them using your hands.
    • Set the desktop down horizontally with the front side facing you.
  2. HP rp5700 Hard Drive Replacement: Schritt 2, Bild 1 von 2 HP rp5700 Hard Drive Replacement: Schritt 2, Bild 2 von 2
    • Hold the desktop with two hands by grasping both sides of the desktop.
    • Press the buttons on both sides using your index fingers.
  3. HP rp5700 Hard Drive Replacement: Schritt 3, Bild 1 von 3 HP rp5700 Hard Drive Replacement: Schritt 3, Bild 2 von 3 HP rp5700 Hard Drive Replacement: Schritt 3, Bild 3 von 3
    • Slide the top cover about an inch forward using your thumb to push it towards you.
    • Make sure that the bottom is still secured by both hands.
    • Lay the desktop back on the table and pull the case forward as far as it can go.
    • Lift the cover up and off.
  4. HP rp5700 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 1 von 2 HP rp5700 Hard Drive Replacement, Hard Drive: Schritt 4, Bild 2 von 2
    • Using your right hand, grip the CD drive and lift it up to a 90 degree position.
  5. HP rp5700 Hard Drive Replacement: Schritt 5, Bild 1 von 2 HP rp5700 Hard Drive Replacement: Schritt 5, Bild 2 von 2
    • Use your hand, whichever you prefer, to grip the two cords on the CD drive and remove the two cords by pulling up.
    • Repeat the same process to remove the two cords connected to the Hard Drive.
  6. HP rp5700 Hard Drive Replacement: Schritt 6, Bild 1 von 1
    • Use your right index finger to pull forward the green flap on the side of the hard drive.
    • At the same time as you are lifting the green flap, use your left hand to lift the hard drive up and out.
Abschluss
8 weitere Nutzer:innen haben diese Anleitung absolviert.
Alyssa Briones
1.699 Reputation
9 Anleitungen geschrieben
Cal Poly, Team 6-23, Maness Winter 2014 Mitglied von Cal Poly, Team 6-23, Maness Winter 2014
CPSU-MANESS-W14S6G23
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 10
Letzte 30 Tage: 23
Insgesamt: 3,746
