Zum Hauptinhalt wechseln
Toshiba Satellite P205-S8811 RAM Replacement
Was du brauchst
  1. Toshiba Satellite P205-S8811 RAM Replacement, Battery: Schritt 1, Bild 1 von 2 Toshiba Satellite P205-S8811 RAM Replacement, Battery: Schritt 1, Bild 2 von 2
    • Flip the laptop over so the bottom is facing upward and the battery is on top.
    • Slide the tab below the battery to the left.
  2. Toshiba Satellite P205-S8811 RAM Replacement: Schritt 2, Bild 1 von 2 Toshiba Satellite P205-S8811 RAM Replacement: Schritt 2, Bild 2 von 2
    • Slide and hold the tab on the right side of the battery to the right.
    • While holding the right tab, slide the battery upward and out its socket.
  3. Toshiba Satellite P205-S8811 RAM Replacement, RAM: Schritt 3, Bild 1 von 1
    • Locate the RAM slot cover on the bottom of the laptop. The RAM slot cover is located near the battery slot.
  4. Toshiba Satellite P205-S8811 RAM Replacement: Schritt 4, Bild 1 von 1
    • Using a Phillips-head screwdriver, unscrew and remove the screw holding the RAM slot cover in place.
  5. Toshiba Satellite P205-S8811 RAM Replacement: Schritt 5, Bild 1 von 2 Toshiba Satellite P205-S8811 RAM Replacement: Schritt 5, Bild 2 von 2
    • Lift and remove the RAM slot cover.
  6. Toshiba Satellite P205-S8811 RAM Replacement: Schritt 6, Bild 1 von 2 Toshiba Satellite P205-S8811 RAM Replacement: Schritt 6, Bild 2 von 2
    • To remove the first RAM chip, gently press outward on the tabs on both sides of the chip
    • The RAM chip should pop up after releasing the tabs.
  7. Toshiba Satellite P205-S8811 RAM Replacement: Schritt 7, Bild 1 von 1
    • Using your fingers, remove the RAM chip by gently pulling it out of the RAM slot.
  8. Toshiba Satellite P205-S8811 RAM Replacement: Schritt 8, Bild 1 von 2 Toshiba Satellite P205-S8811 RAM Replacement: Schritt 8, Bild 2 von 2
    • To remove the second RAM chip, repeat the previous steps
Abschluss
Davin
271 Reputation
2 Anleitungen geschrieben
Cal Poly, Team 2-8, Amido Winter 2014 Mitglied von Cal Poly, Team 2-8, Amido Winter 2014
CPSU-AMIDO-W14S2G8
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 14
Insgesamt: 467
