Zum Hauptinhalt wechseln
Samsung YP-P3 Battery Replacement
Was du brauchst
  1. Samsung YP-P3 Battery Replacement, Case Backplate: Schritt 1, Bild 1 von 1
    • Pry up the small black piece of plastic located between the volume [-] button and the HOLD/ON button.
  2. Samsung YP-P3 Battery Replacement: Schritt 2, Bild 1 von 1
    • Underneath the piece of plastic you just removed, there is a small screw (Phillips #000, 2.0 mm long). Use a Phillips #000 screwdriver to remove it.
  3. Samsung YP-P3 Battery Replacement: Schritt 3, Bild 1 von 2 Samsung YP-P3 Battery Replacement: Schritt 3, Bild 2 von 2
    • Push on the backplate with both thumbs, sliding it towards the top of the device.
    • Once it begins to move, lift up slightly. You can then slide the backplate all the way off.
  4. Samsung YP-P3 Battery Replacement, Printed Circuit Board: Schritt 4, Bild 1 von 3 Samsung YP-P3 Battery Replacement, Printed Circuit Board: Schritt 4, Bild 2 von 3 Samsung YP-P3 Battery Replacement, Printed Circuit Board: Schritt 4, Bild 3 von 3
    • Before removing the circuit board, we must remove the ribbon-like wires attached to two sides of the circuit board.
    • There are two screws (Phillips #000, 2.0 mm long) holding in the circuit board. Use a Phillips #000 screwdriver to take out those screws.
  5. Samsung YP-P3 Battery Replacement: Schritt 5, Bild 1 von 2 Samsung YP-P3 Battery Replacement: Schritt 5, Bild 2 von 2
    • The battery is also attached to the circuit board by a cable. The cable is difficult to disconnect with both components in place. It's best to lift the circuit board out partially to give yourself more room to disconnect the connector.
    • The wire that is connected to the circuit board is connected by a plastic piece with two metal prongs.
    • Use the pointy end of the spudger to place in between the computer board and the plastic piece and gently pry the prongs away from the circuit board.
  6. Samsung YP-P3 Battery Replacement: Schritt 6, Bild 1 von 1
    • Disconnect the battery connector, and then lift the circuit board up.
  7. Samsung YP-P3 Battery Replacement: Schritt 7, Bild 1 von 1
    • Finally, disconnect the ribbon cable on the bottom of the circuit board. You can then lift the circuit board all the way out.
  8. Samsung YP-P3 Battery Replacement, Battery: Schritt 8, Bild 1 von 1
    • Use the spudger to carefully pry up the battery. The battery is attached with a few spots of glue, so it may not move at first.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Michigan Tech, Team 5-7, Lauer Spring 2014 Mitglied von Michigan Tech, Team 5-7, Lauer Spring 2014
MTU-LAUER-S14S5G7
3 Mitglieder
2 Anleitungen geschrieben
2 Kommentare
I had to replace the battery two years ago and again today. This guide made it very easy for me. I was able to change batteries without completely removing the circuit board, but did remove the two screws and ribbon cables on the top of the board to lift up one end of the board.
Thanks for creating this guide!
dbgarlikov - Antwort
Well done, thank you, now to find a digitizer screen, do you know?
Paul Rominger - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 12
Letzte 30 Tage: 42
Insgesamt: 6,949
