Zum Hauptinhalt wechseln
Sony Cyber-shot DSC-W5 LCD Screen Replacement
Was du brauchst
  1. Sony Cyber-shot DSC-W5 LCD Screen Replacement, Back Cover: Schritt 1, Bild 1 von 1
    • Remove Memory Stick Pro from the card reader slot on the bottom of the camera.
    • Remove both batteries.
  2. Sony Cyber-shot DSC-W5 LCD Screen Replacement: Schritt 2, Bild 1 von 2 Sony Cyber-shot DSC-W5 LCD Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove the single visible screw from both sides of the camera.
    • Remove the two screws that are adjacent to the warning label, which is on the underside of the camera.
    • Do NOT remove all four screws from the bottom.
  3. Sony Cyber-shot DSC-W5 LCD Screen Replacement: Schritt 3, Bild 1 von 2 Sony Cyber-shot DSC-W5 LCD Screen Replacement: Schritt 3, Bild 2 von 2
    • Gently remove the back cover from the camera.
    • The first time the case is removed, it will be stiff. Be patient and gently rock the cover back and forth until it slides free.
  4. Sony Cyber-shot DSC-W5 LCD Screen Replacement, LCD Screen: Schritt 4, Bild 1 von 2 Sony Cyber-shot DSC-W5 LCD Screen Replacement, LCD Screen: Schritt 4, Bild 2 von 2
    • Remove the two screws holding the circuit board down.
  5. Sony Cyber-shot DSC-W5 LCD Screen Replacement: Schritt 5, Bild 1 von 1
    • Detach the orange cable from the board.
    • Use a thin object, like a paperclip, to gently pry the cable off the connector.
  6. Sony Cyber-shot DSC-W5 LCD Screen Replacement: Schritt 6, Bild 1 von 2 Sony Cyber-shot DSC-W5 LCD Screen Replacement: Schritt 6, Bild 2 von 2
    • The LCD screen sits in two slots; one on the bottom, and one on the left edge.
    • Slide LCD screen from the two slots.
    • Do not attempt to completely remove the screen, as it is still attached to the camera.
  7. Sony Cyber-shot DSC-W5 LCD Screen Replacement: Schritt 7, Bild 1 von 3 Sony Cyber-shot DSC-W5 LCD Screen Replacement: Schritt 7, Bild 2 von 3 Sony Cyber-shot DSC-W5 LCD Screen Replacement: Schritt 7, Bild 3 von 3
    • To remove the LCD screen, detach the orange cable from the board.
    • If needed, replace the LCD screen.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
Thomas
133 Reputation
6 Anleitungen geschrieben
Cal Poly, Team 15-50, Garner Spring 2010 Mitglied von Cal Poly, Team 15-50, Garner Spring 2010
CPSU-GARNER-S10S15G50
5 Mitglieder
12 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 11,358
