Zum Hauptinhalt wechseln
Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement
Was du brauchst
  1. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Left Shell: Schritt 1, Bild 1 von 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Left Shell: Schritt 1, Bild 2 von 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Left Shell: Schritt 1, Bild 3 von 3
    • Before disassembling your Nerf Hail-Fire, be sure to remove the batteries.
    • Remove the two 9.0 mm Phillips screws securing the battery compartment.
    • Slide the battery compartment out.
  2. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 2, Bild 1 von 1
    • Remove the five 9.0 mm Phillips screws securing the trigger.
  3. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 3, Bild 1 von 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 3, Bild 2 von 2
    • Remove the single 11.0 mm Phillips screw securing the magazine cartridge chambers.
    • Pull the entire chamber upwards to separate it from the rest of the Nerf Gun.
  4. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 4, Bild 1 von 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 4, Bild 2 von 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 4, Bild 3 von 3
    • Remove both halves of the ring by tugging on it upwards until the lock gets freed.
    • This requires quite a bit of force and if you are not careful, you may break the plastic lock.
  5. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 5, Bild 1 von 1
    • Remove the four 9.0 mm Phillips screws from the newly revealed cylinder.
  6. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 6, Bild 1 von 1
    • Remove the three 9.0 mm Phillips screws holding the top latch of the Nerf Gun together.
  7. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 7, Bild 1 von 1
    • Remove the three 9.0 mm Phillips screws holding together the firing chamber.
    • Remove the single 7.0 mm Phillips screw below the barrel.
    • Remove the two 14.0 mm Philips screws using a screwdriver with a length of approximately 4.0 inches and a diameter of approximately 0.2 cm.
  8. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 8, Bild 1 von 1
    • Remove the single 14.0 mm Phillips screw holding together the handle and the Nerf Gun.
  9. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 9, Bild 1 von 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 9, Bild 2 von 2
    • Remove the two 9.0 mm Phillips screws holding together the handle.
    • Remove the plastic cover of the handle.
  10. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 10, Bild 1 von 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 10, Bild 2 von 2
    • Insert one plastic opening tool inside one side of the orange part depicted in the picture.
    • Insert a second plastic opening tool to the other side of the orange part and gradually pull the piece out, freeing it from the handle.
  11. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 11, Bild 1 von 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 11, Bild 2 von 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 11, Bild 3 von 3
    • Pull one end of the handle away from the orange latch.
    • Repeat the procedure on the other side to completely remove the handle from the rest of the Nerf Gun.
  12. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 12, Bild 1 von 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 12, Bild 2 von 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 12, Bild 3 von 3
    • Lift the entire left shell slowly. The process should be easy and if there is any resistance, there is something wrong. You may have forgotten a screw.
    • Completely remove the left shell from the rest of the Nerf Gun.
  13. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Inner Plastic Components: Schritt 13, Bild 1 von 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Inner Plastic Components: Schritt 13, Bild 2 von 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement, Inner Plastic Components: Schritt 13, Bild 3 von 3
    • Remove the cartridge support.
  14. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 14, Bild 1 von 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 14, Bild 2 von 3 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 14, Bild 3 von 3
    • Remove the handle crank.
  15. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 15, Bild 1 von 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 15, Bild 2 von 2
    • Remove the clear plastic barrel cover.
  16. Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 16, Bild 1 von 2 Nerf N-Strike Elite Hail-Fire Inner Plastic Components Replacement: Schritt 16, Bild 2 von 2
    • Remove the firing pin.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
sage
301 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 13-13, Regan Winter 2014 Mitglied von Cal Poly, Team 13-13, Regan Winter 2014
CPSU-REGAN-W14S13G13
4 Mitglieder
7 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 12
Insgesamt: 1,198
