Einleitung
Taking the outer shell off is very easy and all of the internals are visible when it is removed.
Was du brauchst
Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
4 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
What are you trying to do? All of the innards are available once step 3 is complete.
Hi, just to say that its a utility named ProxyTool from Logitech that can be used to adjust the behavior of hand detection feature. here you go the file: ftp://ftp.logitech.com/pub/techsupport/m... or https://www.dropbox.com/s/z1rq7s6wzt4ohu...
You can literaly disable the Couch Mouse M515 hand proximity sensor
M545 works similarly btw
