Zum Hauptinhalt wechseln
Logitech M515 (Couch) Mouse
Was du brauchst
  1. Logitech M515 (Couch) Mouse, Removing the outer shell: Schritt 1, Bild 1 von 1
    • Remove the battery hatch and batteries.
  2. Logitech M515 (Couch) Mouse: Schritt 2, Bild 1 von 1
    • Remove the single Phillips screw located between the battery sockets.
  3. Logitech M515 (Couch) Mouse: Schritt 3, Bild 1 von 1
    • Lift the rear of the top case of the mouse and slide forward. It should be fairly easy to release.
Abschluss
4 weitere Nutzer:innen haben diese Anleitung absolviert.
4 Kommentare
I got to step 3. where is step 4?
hawaii50 - Antwort
What are you trying to do? All of the innards are available once step 3 is complete.
Anna Sweetnam - Antwort
Hi, just to say that its a utility named ProxyTool from Logitech that can be used to adjust the behavior of hand detection feature. here you go the file: ftp://ftp.logitech.com/pub/techsupport/m... or https://www.dropbox.com/s/z1rq7s6wzt4ohu...
You can literaly disable the Couch Mouse M515 hand proximity sensor
Luis Frederico - Antwort
M545 works similarly btw
Adri Idzwan Mansor - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 3
Letzte 30 Tage: 16
Insgesamt: 4,920
