Zum Hauptinhalt wechseln
Sega Game Gear Case Replacement
Was du brauchst
  1. Sega Game Gear Case Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place your device upside down and locate the two battery compartments.
  2. Sega Game Gear Case Replacement: Schritt 2, Bild 1 von 1
    • Press on the tabs at the bottom of the battery covers then lift up to remove.
    • Remove batteries if they are present.
  3. Sega Game Gear Case Replacement, Case: Schritt 3, Bild 1 von 1
    • Remove the following screws:
    • Six Phillips screws
    • One 4.5 mm Gamebit screw
  4. Sega Game Gear Case Replacement: Schritt 4, Bild 1 von 1
    • Use tweezers to take all other screws out.
  5. Sega Game Gear Case Replacement: Schritt 5, Bild 1 von 2 Sega Game Gear Case Replacement: Schritt 5, Bild 2 von 2
    • Gently open the case by unfolding it over the top of the Sega Game Gear.
    • Do not pull the back of the case away, as cables are connected between both sides.
  6. Sega Game Gear Case Replacement: Schritt 6, Bild 1 von 3 Sega Game Gear Case Replacement: Schritt 6, Bild 2 von 3 Sega Game Gear Case Replacement: Schritt 6, Bild 3 von 3
    • Carefully unplug the 2 white-tipped connectors on the top cover.
Abschluss
9 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 28-33, Regan Spring 2010 Mitglied von Cal Poly, Team 28-33, Regan Spring 2010
CPSU-REGAN-S10S28G33
5 Mitglieder
13 Anleitungen geschrieben
Ein Kommentar
Is this guide made to help replacing the Game Gear shell? Almost doesn't seem like a thorough guide, I'm still seeing screws on the motherboard in the last photo, I assume those get taken out too?
Alex Tomalty - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 5
Letzte 7 Tage: 26
Letzte 30 Tage: 102
Insgesamt: 19,638
