Zum Hauptinhalt wechseln
Sega Game Gear Screen Replacement
Was du brauchst
  1. Sega Game Gear Screen Replacement, Battery: Schritt 1, Bild 1 von 1
    • Place your device upside down and locate the two battery compartments.
  2. Sega Game Gear Screen Replacement: Schritt 2, Bild 1 von 1
    • Press on the tabs at the bottom of the battery covers then lift up to remove.
    • Remove batteries if they are present.
  3. Sega Game Gear Screen Replacement, Case: Schritt 3, Bild 1 von 1
    • Remove the following screws:
    • Six Phillips screws
    • One 4.5 mm Gamebit screw
  4. Sega Game Gear Screen Replacement: Schritt 4, Bild 1 von 1
    • Use tweezers to take all other screws out.
  5. Sega Game Gear Screen Replacement: Schritt 5, Bild 1 von 2 Sega Game Gear Screen Replacement: Schritt 5, Bild 2 von 2
    • Gently open the case by unfolding it over the top of the Sega Game Gear.
    • Do not pull the back of the case away, as cables are connected between both sides.
  6. Sega Game Gear Screen Replacement: Schritt 6, Bild 1 von 3 Sega Game Gear Screen Replacement: Schritt 6, Bild 2 von 3 Sega Game Gear Screen Replacement: Schritt 6, Bild 3 von 3
    • Carefully unplug the 2 white-tipped connectors on the top cover.
  7. Sega Game Gear Screen Replacement, Screen: Schritt 7, Bild 1 von 1
    • Unscrew all the marked screws.
  8. Sega Game Gear Screen Replacement: Schritt 8, Bild 1 von 1
    • Slide the logic board out from under the circular black fastener at the top-left corner of the case.
  9. Sega Game Gear Screen Replacement: Schritt 9, Bild 1 von 1
    • Place the board onto a flat surface.
    • Small plastic buttons may fall off during this process, save them in a container or a place where they could be found later on.
  10. Sega Game Gear Screen Replacement: Schritt 10, Bild 1 von 1
    • Unscrew the marked screws.
    • Flip the board, having its back facing up.
    • Hold onto the screen in the back, as it will flip open if not held onto.
  11. Sega Game Gear Screen Replacement: Schritt 11, Bild 1 von 2 Sega Game Gear Screen Replacement: Schritt 11, Bild 2 von 2
    • Make sure the screen is towards the bottom, as indicated in the second picture.
  12. Sega Game Gear Screen Replacement: Schritt 12, Bild 1 von 2 Sega Game Gear Screen Replacement: Schritt 12, Bild 2 von 2
    • Gently open the screen up.
    • The screen will not come out all the way since it is glued onto the top side.
Abschluss
13 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 28-33, Regan Spring 2010 Mitglied von Cal Poly, Team 28-33, Regan Spring 2010
CPSU-REGAN-S10S28G33
5 Mitglieder
13 Anleitungen geschrieben
9 Kommentare
any one know where to get a new display that wont bleed me dry?
isaiah bellamy (masta ike) - Antwort
Due to the nature a Game Gear screen attaches, a ribbon directly soldered to the mainboard, replacing it requires a soldering iron and some fairly advanced technique.
This guide, titled “Sega Game Gear Screen Replacement”, only takes us to the point you remove the ribbon. There is much work left.
Anthony Bessel - Antwort
so, uh, is there a more comprehensive version somewhere?
rollin -
Does the screen get fixed at the end?
Caedmon O’Brien - Antwort
SadlySadly, in step 7 you missed a screw location
talliesine - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 11
Letzte 7 Tage: 62
Letzte 30 Tage: 250
Insgesamt: 64,839
