Zum Hauptinhalt wechseln
Disassembling KDDI Kyocera A5521K Back Plate
Was du brauchst
  1. Disassembling KDDI Kyocera A5521K Back Plate, Disassembling KDDI Kyocera A5521K Battery: Schritt 1, Bild 1 von 3 Disassembling KDDI Kyocera A5521K Back Plate, Disassembling KDDI Kyocera A5521K Battery: Schritt 1, Bild 2 von 3 Disassembling KDDI Kyocera A5521K Back Plate, Disassembling KDDI Kyocera A5521K Battery: Schritt 1, Bild 3 von 3
    • Turn the phone over to expose the battery cover.
    • Apply pressure to the back of the battery cover to slide it down.
    • The battery cover is now separate from the phone.
  2. Disassembling KDDI Kyocera A5521K Back Plate: Schritt 2, Bild 1 von 3 Disassembling KDDI Kyocera A5521K Back Plate: Schritt 2, Bild 2 von 3 Disassembling KDDI Kyocera A5521K Back Plate: Schritt 2, Bild 3 von 3
    • Remove the battery by pushing it up and out from the bottom.
    • The battery, cover, and phone should now be separated.
  3. Disassembling KDDI Kyocera A5521K Back Plate, Back Plate: Schritt 3, Bild 1 von 2 Disassembling KDDI Kyocera A5521K Back Plate, Back Plate: Schritt 3, Bild 2 von 2
    • Remove the four screws with the Y0 screwdriver.
  4. Disassembling KDDI Kyocera A5521K Back Plate: Schritt 4, Bild 1 von 2 Disassembling KDDI Kyocera A5521K Back Plate: Schritt 4, Bild 2 von 2
    • Remove the black, rubber screw caps towards the top of the back of the phone to reveal two additional screws.
    • Remove the two screws with a Y0 screwdriver.
  5. Disassembling KDDI Kyocera A5521K Back Plate: Schritt 5, Bild 1 von 3 Disassembling KDDI Kyocera A5521K Back Plate: Schritt 5, Bild 2 von 3 Disassembling KDDI Kyocera A5521K Back Plate: Schritt 5, Bild 3 von 3
    • Rotate the phone 180 degrees.
    • Carefully separate the back plate from the remainder of the phone.
    • The back plate should now be detached from the rest of the phone.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
Dominic Grisafe
157 Reputation
10 Anleitungen geschrieben
Cal Poly, Team 28-25, Regan Spring 2010 Mitglied von Cal Poly, Team 28-25, Regan Spring 2010
CPSU-REGAN-S10S28G25
4 Mitglieder
20 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 2,822
