Zum Hauptinhalt wechseln
Olympus D590 Face Plate Replacement
Was du brauchst
  1. Olympus D590 Face Plate Replacement, Face Plate: Schritt 1, Bild 1 von 1
    • Remove five baseplate screws using a Phillips #00 screwdriver.
  2. Olympus D590 Face Plate Replacement: Schritt 2, Bild 1 von 1
    • Press and slide the battery cover retainer clip to the left. Use tweezers to lift the battery cover away.
  3. Olympus D590 Face Plate Replacement: Schritt 3, Bild 1 von 1
    • Remove the single screw from the battery housing using a Phillips #00 screwdriver.
  4. Olympus D590 Face Plate Replacement: Schritt 4, Bild 1 von 1
    • Using tweezers, lift the rubber plate to expose the ports.
  5. Olympus D590 Face Plate Replacement: Schritt 5, Bild 1 von 1
    • Remove two screws from the ports using a Phillips #00 screwdriver.
  6. Olympus D590 Face Plate Replacement: Schritt 6, Bild 1 von 1
    • Use a spudger to pry the faceplate away from the rest of the camera.
  7. Olympus D590 Face Plate Replacement: Schritt 7, Bild 1 von 1
    • To avoid disconnection of the connector line to the motherboard, use caution when pulling faceplate away from camera case.
    • Damage to the connector line will prevent the on/off power switch's operational function.
Abschluss
Katie
31 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 28-23, Regan Spring 2010 Mitglied von Cal Poly, Team 28-23, Regan Spring 2010
CPSU-REGAN-S10S28G23
4 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 7
Letzte 30 Tage: 15
Insgesamt: 1,614
