Zum Hauptinhalt wechseln
HP Media Center 876x Front Cover Replacement
Was du brauchst
  1. HP Media Center 876x Front Cover Replacement, Side Panel: Schritt 1, Bild 1 von 2 HP Media Center 876x Front Cover Replacement, Side Panel: Schritt 1, Bild 2 von 2
    • Remove the two (9 mm) hand screws on the back panel.
  2. HP Media Center 876x Front Cover Replacement: Schritt 2, Bild 1 von 3 HP Media Center 876x Front Cover Replacement: Schritt 2, Bild 2 von 3 HP Media Center 876x Front Cover Replacement: Schritt 2, Bild 3 von 3
    • Place the tower on its side.
    • Slide the side panel horizontally to detach, and pull upward to remove.
  3. HP Media Center 876x Front Cover Replacement, Front Cover: Schritt 3, Bild 1 von 2 HP Media Center 876x Front Cover Replacement, Front Cover: Schritt 3, Bild 2 von 2
    • Orient the tower vertically.
    • Using the #0 Phillips head screwdriver, unscrew and remove the two (5 mm) screws that fasten the remaining side panel to the tower.
    • Slide the side panel out of its notches, and pull it gently off of the tower.
  4. HP Media Center 876x Front Cover Replacement: Schritt 4, Bild 1 von 1
    • Gently move the tower so that it is in the horizontal orientation.
    • Press down the black tabs (proximal to you) that fasten the front panel to the tower.
    • Press down on the distal, black tabs (symmetric with respect to the previous tabs).
    • Pull front panel forward slightly.
  5. HP Media Center 876x Front Cover Replacement: Schritt 5, Bild 1 von 2 HP Media Center 876x Front Cover Replacement: Schritt 5, Bild 2 von 2
    • The front panel will come off in a hinge-like fashion, exposing the drives underneath.
Abschluss
Clemson, Team 6-1, Benson Spring 2014 Mitglied von Clemson, Team 6-1, Benson Spring 2014
CLEM-BENSON-S14S6G1
3 Mitglieder
15 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 5
Letzte 30 Tage: 19
Insgesamt: 422
