Zum Hauptinhalt wechseln
Dell Latitude X300 Screen Replacement
Was du brauchst
  1. Dell Latitude X300 Screen Replacement, Screen: Schritt 1, Bild 1 von 1
    • Make sure the Dell Latitude X300 power is off.
    • Remove the battery located on the bottom of the device by pushing in both clips.
  2. Dell Latitude X300 Screen Replacement: Schritt 2, Bild 1 von 2 Dell Latitude X300 Screen Replacement: Schritt 2, Bild 2 von 2
    • Remove rubber caps on each corner of the front screen with a pinch.
    • Remove the 4 mm screws located on the front screen of the laptop.
  3. Dell Latitude X300 Screen Replacement: Schritt 3, Bild 1 von 1
    • Carefully, remove the screen casing using either your hands or a proper tool.
    • The casing is very flimsy, so extreme care is required.
  4. Dell Latitude X300 Screen Replacement: Schritt 4, Bild 1 von 1
    • Remove the 4 mm screws on the bottom left and bottom right corner of the screen.
  5. Dell Latitude X300 Screen Replacement: Schritt 5, Bild 1 von 2 Dell Latitude X300 Screen Replacement: Schritt 5, Bild 2 von 2
    • Carefully lift the screen and place it on it's face.
    • Disconnect the wiring attached to the screen.
    • It is important not to damage this wire.
Abschluss
3 weitere Nutzer:innen haben diese Anleitung absolviert.
Jacob
9 Reputation
2 Anleitungen geschrieben
UMass Dartmouth, Team 6-1, Vijaybhaskar Spring 2014 Mitglied von UMass Dartmouth, Team 6-1, Vijaybhaskar Spring 2014
UMASSD-VIJAYBHASKAR-S14S6G1
4 Mitglieder
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 703
