Zum Hauptinhalt wechseln
HP Pavilion dv6000 Speaker Bar Replacement
Was du brauchst
  1. HP Pavilion dv6000 Speaker Bar Replacement, Speaker Bar: Schritt 1, Bild 1 von 1
    • Make sure the laptop lid is closed, turn it over and remove the battery by moving the switch right to left.
    • there are three philips screws located on the surface where the writing is. remove those three screws.
  2. HP Pavilion dv6000 Speaker Bar Replacement: Schritt 2, Bild 1 von 1
    • turn the laptop right side up. Between the cover and case on the top right of the laptop and using a plastic sludger or a finger lift gently on the speaker cover as to disengage the clips.
    • Be sure not to pull hard or you may damage the ribbon cables.
    • From the side closest to the screen turn the cover towards yourself.
  3. HP Pavilion dv6000 Speaker Bar Replacement: Schritt 3, Bild 1 von 1
    • there is one connector from the speaker bar to a control board. Gently remove the cable.
    • There are two more screws attaching the speaker bar to the cover, remove these and take the speaker bar out.
  4. HP Pavilion dv6000 Speaker Bar Replacement: Schritt 4, Bild 1 von 1
    • you are now ready to replace or repair the speaker bar. I recomend purchasing a new one, they range anywhere from 5-15 dollars online.
Abschluss
5 weitere Nutzer:innen haben diese Anleitung absolviert.
Joba Fett
227 Reputation
1 Anleitung geschrieben
2 Kommentare
how to fix speaker from board
kingsley Osunkwo - Antwort
Grazie siete bravissimi . Ce ne fossero persone come voi che altruisticamente mettono a disposizione la loro esperienza di riparazioni per gli altri!
Fernando Mancini
fernando mancini - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 4
Letzte 30 Tage: 14
Insgesamt: 3,442
