Zum Hauptinhalt wechseln
Compaq Evo N1000v Heat Sink Replacement
Was du brauchst
  1. Compaq Evo N1000v Heat Sink Replacement, LED Cover: Schritt 1, Bild 1 von 1
    • Flip the laptop over with the rear panel facing forward.
  2. Compaq Evo N1000v Heat Sink Replacement: Schritt 2, Bild 1 von 1
    • Using a TR8 Torx screwdriver, remove the two T8 Torx screws that secure the LED cover to the base enclosure.
  3. Compaq Evo N1000v Heat Sink Replacement: Schritt 3, Bild 1 von 1
    • Flip the laptop back over with the front facing forward. Open the screen.
  4. Compaq Evo N1000v Heat Sink Replacement: Schritt 4, Bild 1 von 1
    • Locate the F1 and F2 keys near the top left corner of the keyboard.
  5. Compaq Evo N1000v Heat Sink Replacement: Schritt 5, Bild 1 von 1
    • While holding the F1 and F2 keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  6. Compaq Evo N1000v Heat Sink Replacement: Schritt 6, Bild 1 von 1
    • Locate the Scroll and Pause keys near the top right corner of the keyboard.
  7. Compaq Evo N1000v Heat Sink Replacement: Schritt 7, Bild 1 von 1
    • While holding the Scroll and Pause keys, insert a spudger between the keys into the notch in the LED cover. Lift up.
  8. Compaq Evo N1000v Heat Sink Replacement: Schritt 8, Bild 1 von 2 Compaq Evo N1000v Heat Sink Replacement: Schritt 8, Bild 2 von 2
    • Insert a spudger between the F7 and F8 keys. Lift up to remove the LED cover.
  9. Compaq Evo N1000v Heat Sink Replacement, Keyboard: Schritt 9, Bild 1 von 1
    • Lift the back edge of the keyboard and pull towards the screen.
  10. Compaq Evo N1000v Heat Sink Replacement: Schritt 10, Bild 1 von 1
    • Pull the cable and lift up to release.
  11. Compaq Evo N1000v Heat Sink Replacement: Schritt 11, Bild 1 von 1
    • Remove the keyboard.
  12. Compaq Evo N1000v Heat Sink Replacement, Heat Sink: Schritt 12, Bild 1 von 1
    • Disconnect the cable connecting the fan to the system board.
  13. Compaq Evo N1000v Heat Sink Replacement: Schritt 13, Bild 1 von 1
    • Remove the four screws from the heat sink.
  14. Compaq Evo N1000v Heat Sink Replacement: Schritt 14, Bild 1 von 1
    • Pull the the heat sink up and out of the computer.
Abschluss
2 weitere Nutzer:innen haben diese Anleitung absolviert.
kim
59 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 29-74, Johann Spring 2010 Mitglied von Cal Poly, Team 29-74, Johann Spring 2010
CPSU-JOHANN-S10S29G74
3 Mitglieder
14 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 17
Insgesamt: 4,010
