Einleitung
The front faceplate protects the components inside the radio. To replace inside components, the front faceplate of the radio must be removed. Follow the steps below to properly open the radio.
Was du brauchst
Remove the back battery cover by pressing the tab to the left, and lifting.
Remove the batteries currently in the radio.
The orientation of the batteries is specified in the battery compartment.
Firmly grasp and pull back on the volume knob. The knob should come off smoothly.
Remove the four 3 millimeter T6 Torx screws from the front of the radio.
Gently open the backplate of the radio. Use a flathead screwdriver to slowly pry apart the two sides.
