Zum Hauptinhalt wechseln
Removing Dell Inspiron 1150 RAM
Was du brauchst
  1. Removing Dell Inspiron 1150 RAM, Removing Dell Inspiron 1150 RAM: Schritt 1, Bild 1 von 1
    • Turn the laptop so that the bottom is facing up.
    • Locate the panel that has an M on it and two air vents.
  2. Removing Dell Inspiron 1150 RAM: Schritt 2, Bild 1 von 2 Removing Dell Inspiron 1150 RAM: Schritt 2, Bild 2 von 2
    • Take the screw driver and carefully unscrew the screw that is located above the M in order to remove the panel.
    • Put this screw in a bag or easily identifiable place.
    • Remove the panel.
  3. Removing Dell Inspiron 1150 RAM: Schritt 3, Bild 1 von 3 Removing Dell Inspiron 1150 RAM: Schritt 3, Bild 2 von 3 Removing Dell Inspiron 1150 RAM: Schritt 3, Bild 3 von 3
    • After removing the panel, you will see two memory modules.
    • Locate the four spring clips that are holding the memory modules in place.
    • Place your thumb on each of the two spring clips for each memory module and push outward until the memory module pops up.
    • Gently raise the memory module and lift it out of its socket.
Abschluss
Cal Poly, Team 16-2, Maness Spring 2010 Mitglied von Cal Poly, Team 16-2, Maness Spring 2010
CPSU-MANESS-S10S16G2
4 Mitglieder
9 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 8
Letzte 30 Tage: 21
Insgesamt: 5,841
