Zum Hauptinhalt wechseln
Kodak EasyShare C713 LCD Replacement
Was du brauchst
  1. Kodak EasyShare C713 LCD Replacement, Batteries: Schritt 1, Bild 1 von 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 LCD Replacement: Schritt 2, Bild 1 von 1
    • Remove the old batteries.
  3. Kodak EasyShare C713 LCD Replacement, Outer Case: Schritt 3, Bild 1 von 3 Kodak EasyShare C713 LCD Replacement, Outer Case: Schritt 3, Bild 2 von 3 Kodak EasyShare C713 LCD Replacement, Outer Case: Schritt 3, Bild 3 von 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 LCD Replacement: Schritt 4, Bild 1 von 3 Kodak EasyShare C713 LCD Replacement: Schritt 4, Bild 2 von 3 Kodak EasyShare C713 LCD Replacement: Schritt 4, Bild 3 von 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 LCD Replacement, LCD: Schritt 5, Bild 1 von 1
    • The LCD screen is hinged at the bottom.
    • Put your thumb in the upper right corner of the LCD screen.
    • Pull the LCD screen out of its outer case with your thumb.
  6. Kodak EasyShare C713 LCD Replacement: Schritt 6, Bild 1 von 1
    • Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
  7. Kodak EasyShare C713 LCD Replacement: Schritt 7, Bild 1 von 2 Kodak EasyShare C713 LCD Replacement: Schritt 7, Bild 2 von 2
    • Desolder the two points.
    • One on the port side.
    • One on the bottom.
  8. Kodak EasyShare C713 LCD Replacement: Schritt 8, Bild 1 von 1
    • After desoldering the LCD casing, just use your fingers to carefully remove it.
  9. Kodak EasyShare C713 LCD Replacement: Schritt 9, Bild 1 von 1
    • Flip up the black tab on the bottom of the LCD screen with a fingertip.
  10. Kodak EasyShare C713 LCD Replacement: Schritt 10, Bild 1 von 1
    • Remove the LCD ribbon cable from inside the black tab.
Abschluss
6 weitere Nutzer:innen haben diese Anleitung absolviert.
Cal Poly, Team 26-19, Regan Spring 2010 Mitglied von Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Mitglieder
14 Anleitungen geschrieben
2 Kommentare
Thank you... i fixed my old camera lcd.
anthoxman - Antwort
hvor kan jeg kjøpe LCD skjermen til dette kamerat, og hva koster et sånn LCD-skjerm
fancy tassen - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 11
Letzte 30 Tage: 29
Insgesamt: 5,274
