Zum Hauptinhalt wechseln
Kodak EasyShare C713 Lens Replacement
Was du brauchst
  1. Kodak EasyShare C713 Lens Replacement, Batteries: Schritt 1, Bild 1 von 1
    • Use your finger tip to slide battery cover door away from the center of the camera.
    • The battery door should spring open.
    • If this does not happen, gently open the door lifting from the outer bottom side of the camera.
  2. Kodak EasyShare C713 Lens Replacement: Schritt 2, Bild 1 von 1
    • Remove the old batteries.
  3. Kodak EasyShare C713 Lens Replacement, Outer Case: Schritt 3, Bild 1 von 3 Kodak EasyShare C713 Lens Replacement, Outer Case: Schritt 3, Bild 2 von 3 Kodak EasyShare C713 Lens Replacement, Outer Case: Schritt 3, Bild 3 von 3
    • Remove the seven screws from the outer case with a Phillips #00.
    • All screws are 4.45mm.
    • There are 2 screws on the port side.
    • There are 2 screws on starboard side.
    • There are 3 screws on the bottom.
  4. Kodak EasyShare C713 Lens Replacement: Schritt 4, Bild 1 von 3 Kodak EasyShare C713 Lens Replacement: Schritt 4, Bild 2 von 3 Kodak EasyShare C713 Lens Replacement: Schritt 4, Bild 3 von 3
    • Make sure the battery cap is "up".
    • Pull the outer case off with your hands.
  5. Kodak EasyShare C713 Lens Replacement, LCD: Schritt 5, Bild 1 von 1
    • The LCD screen is hinged at the bottom.
    • Put your thumb in the upper right corner of the LCD screen.
    • Pull the LCD screen out of its outer case with your thumb.
  6. Kodak EasyShare C713 Lens Replacement: Schritt 6, Bild 1 von 1
    • Remove the screw underneath LCD screen with the Phillips #00. The screw measures 4.1mm in length.
  7. Kodak EasyShare C713 Lens Replacement: Schritt 7, Bild 1 von 2 Kodak EasyShare C713 Lens Replacement: Schritt 7, Bild 2 von 2
    • Desolder the two points.
    • One on the port side.
    • One on the bottom.
  8. Kodak EasyShare C713 Lens Replacement: Schritt 8, Bild 1 von 1
    • After desoldering the LCD casing, just use your fingers to carefully remove it.
  9. Kodak EasyShare C713 Lens Replacement: Schritt 9, Bild 1 von 1
    • Flip up the black tab on the bottom of the LCD screen with a fingertip.
  10. Kodak EasyShare C713 Lens Replacement: Schritt 10, Bild 1 von 1
    • Remove the LCD ribbon cable from inside the black tab.
  11. Kodak EasyShare C713 Lens Replacement, Lens: Schritt 11, Bild 1 von 1
    • Using a fingertip, flip the black tab near the top of the camera.
    • Remove the ribbon connector from inside the black tab.
  12. Kodak EasyShare C713 Lens Replacement: Schritt 12, Bild 1 von 1
    • Remove the remaining eight 4.1mm screws on the back with the Phillips #00 screwdriver.
  13. Kodak EasyShare C713 Lens Replacement: Schritt 13, Bild 1 von 1
    • Desolder the upper points.
    • There is a series of solder points in a rectangular area in the upper middle of the camera.
    • There is a large solder point in the upper right.
  14. Kodak EasyShare C713 Lens Replacement: Schritt 14, Bild 1 von 1
    • Turn the camera over.
    • Remove the silver 2.2mm battery cap screw.
  15. Kodak EasyShare C713 Lens Replacement: Schritt 15, Bild 1 von 2 Kodak EasyShare C713 Lens Replacement: Schritt 15, Bild 2 von 2
    • Pry the capacitor out of its holder on the bottom of the camera with your fingers.
  16. Kodak EasyShare C713 Lens Replacement: Schritt 16, Bild 1 von 3 Kodak EasyShare C713 Lens Replacement: Schritt 16, Bild 2 von 3 Kodak EasyShare C713 Lens Replacement: Schritt 16, Bild 3 von 3
    • Remove the lens assembly with your fingers.
    • You may need to wiggle it back and forth until it comes loose.
    • Do not touch the marked areas. This will cause the camera to take blurry pictures.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Cal Poly, Team 26-19, Regan Spring 2010 Mitglied von Cal Poly, Team 26-19, Regan Spring 2010
CPSU-REGAN-S10S26G19
4 Mitglieder
14 Anleitungen geschrieben
Ein Kommentar
why didn't you mention to discharge the capacitor, its stored charge is pretty high & dangerous
richard - Antwort
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 2
Letzte 7 Tage: 13
Letzte 30 Tage: 27
Insgesamt: 6,965
