Zum Hauptinhalt wechseln
BlackBerry 7100g Housing Replacement
Was du brauchst
  1. BlackBerry 7100g Housing Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Locate the battery cover release button near the bottom of the back panel.
  2. BlackBerry 7100g Housing Replacement: Schritt 2, Bild 1 von 3 BlackBerry 7100g Housing Replacement: Schritt 2, Bild 2 von 3 BlackBerry 7100g Housing Replacement: Schritt 2, Bild 3 von 3
    • Push down on the release button with one thumb.
    • Slide the battery cover off with the other thumb.
  3. BlackBerry 7100g Housing Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery from the battery housing by flipping up the top of the battery.
  4. BlackBerry 7100g Housing Replacement, Housing: Schritt 4, Bild 1 von 3 BlackBerry 7100g Housing Replacement, Housing: Schritt 4, Bild 2 von 3 BlackBerry 7100g Housing Replacement, Housing: Schritt 4, Bild 3 von 3
    • Locate the silver strip near the top of your BlackBerry.
    • Use a plastic opening tool to pry off the edge of the silver lining.
    • Slide the tool along the length of the silver strip to completely remove it.
  5. BlackBerry 7100g Housing Replacement: Schritt 5, Bild 1 von 2 BlackBerry 7100g Housing Replacement: Schritt 5, Bild 2 von 2
    • Do not lose the screws. They are quite small and can easily be misplaced.
    • Locate and unscrew the four (4) screws using a T6 screwdriver.
  6. BlackBerry 7100g Housing Replacement: Schritt 6, Bild 1 von 3 BlackBerry 7100g Housing Replacement: Schritt 6, Bild 2 von 3 BlackBerry 7100g Housing Replacement: Schritt 6, Bild 3 von 3
    • The keypad cover may fall out of the housing when prying the housing apart.
    • Tightly pinch the top of the front and back halves of the housing.
    • Carefully pry the two halves of the housing apart.
  7. BlackBerry 7100g Housing Replacement: Schritt 7, Bild 1 von 1
    • You can now easily remove the "guts" of the phone from the housing.
Abschluss
Ein:e weitere:r Nutzer:in hat diese Anleitung absolviert.
Kellan
277 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 25-87, Amido Spring 2010 Mitglied von Cal Poly, Team 25-87, Amido Spring 2010
CPSU-AMIDO-S10S25G87
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 2
Letzte 30 Tage: 19
Insgesamt: 2,273
