Zum Hauptinhalt wechseln
Olympus Stylus 1030 SW LCD and Button Replacement
Was du brauchst
  1. Olympus Stylus 1030 SW LCD and Button Replacement, Olympus Stylus 1030 SW Camera Disassembly: Schritt 1, Bild 1 von 3 Olympus Stylus 1030 SW LCD and Button Replacement, Olympus Stylus 1030 SW Camera Disassembly: Schritt 1, Bild 2 von 3 Olympus Stylus 1030 SW LCD and Button Replacement, Olympus Stylus 1030 SW Camera Disassembly: Schritt 1, Bild 3 von 3
    • Using the iFixit Opening Tool, pry off the plastic part of the lens.
    • Using the T6 Torx screwdriver, unscrew the three screws.
  2. Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 2, Bild 1 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 2, Bild 2 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 2, Bild 3 von 3
    • Using the Phillips #00 screwdriver, unscrew the three screws.
    • Carefully swivel the metal cover out towards you.
    • Using tweezers, remove the metal washer.
  3. Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 3, Bild 1 von 2 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 3, Bild 2 von 2
    • Using the tweezers, slowly peel off the plate.
  4. Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 4, Bild 1 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 4, Bild 2 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 4, Bild 3 von 3
    • Using the Phillips #00 screwdriver, unscrew the two screws on the side of the camera.
  5. Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 5, Bild 1 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 5, Bild 2 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 5, Bild 3 von 3
    • On the opposite side, use the Phillips #00 screwdriver to unscrew both screws.
    • Take out the speaker plate.
    • Open the multi-connector cover and slide off the side panel.
  6. Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 6, Bild 1 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 6, Bild 2 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 6, Bild 3 von 3
    • Using the Phillips #00 screwdriver, unscrew the screw above the speaker.
    • On the bottom side of the camera, unscrew the two screws.
  7. Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 7, Bild 1 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 7, Bild 2 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 7, Bild 3 von 3
    • Open the battery compartment cover.
    • Use the Phillips #00 screwdriver to unscrew the screw in the battery compartment.
  8. Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 8, Bild 1 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 8, Bild 2 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 8, Bild 3 von 3
    • On the front of the camera, unscrew the two screws shown.
    • Gently pull on the side until the camera is separated from the back panel.
    • Remove the shutter and power button.
  9. Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 9, Bild 1 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 9, Bild 2 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 9, Bild 3 von 3
    • Use the Phillips #00 screwdriver to unscrew the four screws on the front of the camera.
    • Unscrew the shutter using the Phillips #00 screwdriver.
  10. Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 10, Bild 1 von 2 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 10, Bild 2 von 2
    • Release the top holding using a spudger.
    • Slowly and carefully separate the front and back of the camera, exposing the electrical ribbons.
  11. Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 11, Bild 1 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 11, Bild 2 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 11, Bild 3 von 3
    • Using the spudger and tweezers if needed, remove the ribbons from the computer chips.
  12. Olympus Stylus 1030 SW LCD and Button Replacement, LCD and Buttons: Schritt 12, Bild 1 von 3 Olympus Stylus 1030 SW LCD and Button Replacement, LCD and Buttons: Schritt 12, Bild 2 von 3 Olympus Stylus 1030 SW LCD and Button Replacement, LCD and Buttons: Schritt 12, Bild 3 von 3
    • Unscrew the two screws found on the left side of the screen using the PH#00 head.
    • Peel off the gel tape using tweezers.
    • Unscrew the five 0.6 mm screws using the Phillips #00 screwdriver.
  13. Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 13, Bild 1 von 2 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 13, Bild 2 von 2
    • Use the spudger to carefully pry off the LCD screen.
  14. Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 14, Bild 1 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 14, Bild 2 von 3 Olympus Stylus 1030 SW LCD and Button Replacement: Schritt 14, Bild 3 von 3
    • Use the tweezers to take out the rubber button holder and its buttons.
Abschluss
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 0
Letzte 7 Tage: 0
Letzte 30 Tage: 2
Insgesamt: 1,237
