Zum Hauptinhalt wechseln
BlackBerry 7100g Battery Terminal Replacement
Was du brauchst
  1. BlackBerry 7100g Battery Terminal Replacement, Battery: Schritt 1, Bild 1 von 1
    • Turn over your BalckBerry 7100g so that the back cover is facing up.
    • Locate the battery cover release button near the bottom of the back panel.
  2. BlackBerry 7100g Battery Terminal Replacement: Schritt 2, Bild 1 von 3 BlackBerry 7100g Battery Terminal Replacement: Schritt 2, Bild 2 von 3 BlackBerry 7100g Battery Terminal Replacement: Schritt 2, Bild 3 von 3
    • Push down on the release button with one thumb.
    • Slide the battery cover off with the other thumb.
  3. BlackBerry 7100g Battery Terminal Replacement: Schritt 3, Bild 1 von 1
    • Remove the battery from the battery housing by flipping up the top of the battery.
  4. BlackBerry 7100g Battery Terminal Replacement, Housing: Schritt 4, Bild 1 von 3 BlackBerry 7100g Battery Terminal Replacement, Housing: Schritt 4, Bild 2 von 3 BlackBerry 7100g Battery Terminal Replacement, Housing: Schritt 4, Bild 3 von 3
    • Locate the silver strip near the top of your BlackBerry.
    • Use a plastic opening tool to pry off the edge of the silver lining.
    • Slide the tool along the length of the silver strip to completely remove it.
  5. BlackBerry 7100g Battery Terminal Replacement: Schritt 5, Bild 1 von 2 BlackBerry 7100g Battery Terminal Replacement: Schritt 5, Bild 2 von 2
    • Do not lose the screws. They are quite small and can easily be misplaced.
    • Locate and unscrew the four (4) screws using a T6 screwdriver.
  6. BlackBerry 7100g Battery Terminal Replacement: Schritt 6, Bild 1 von 3 BlackBerry 7100g Battery Terminal Replacement: Schritt 6, Bild 2 von 3 BlackBerry 7100g Battery Terminal Replacement: Schritt 6, Bild 3 von 3
    • The keypad cover may fall out of the housing when prying the housing apart.
    • Tightly pinch the top of the front and back halves of the housing.
    • Carefully pry the two halves of the housing apart.
  7. BlackBerry 7100g Battery Terminal Replacement: Schritt 7, Bild 1 von 1
    • You can now easily remove the "guts" of the phone from the housing.
  8. BlackBerry 7100g Battery Terminal Replacement, Battery Terminal: Schritt 8, Bild 1 von 2 BlackBerry 7100g Battery Terminal Replacement, Battery Terminal: Schritt 8, Bild 2 von 2
    • Remove the four screws holding the battery and speaker housing to the motherboard.
  9. BlackBerry 7100g Battery Terminal Replacement: Schritt 9, Bild 1 von 3 BlackBerry 7100g Battery Terminal Replacement: Schritt 9, Bild 2 von 3 BlackBerry 7100g Battery Terminal Replacement: Schritt 9, Bild 3 von 3
    • Once the battery housing is seperated from the motherboard, the battery terminal will slide off the battery housing.
    • The small plastic piece with four metal pins is the battery terminal shown in the third picture.
Abschluss
Kellan
277 Reputation
3 Anleitungen geschrieben
Cal Poly, Team 25-87, Amido Spring 2010 Mitglied von Cal Poly, Team 25-87, Amido Spring 2010
CPSU-AMIDO-S10S25G87
4 Mitglieder
16 Anleitungen geschrieben
0 Kommentare
Kommentar hinzufügen
Seitenaufrufe:
Letzte 24 Stunden: 1
Letzte 7 Tage: 1
Letzte 30 Tage: 3
Insgesamt: 3,090
